- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
31.0.8.1
Debian GNU/Linux 12 (bookworm)
Apache/2.4.62 (Debian)
- PHP version (e.g, 8.3):
PHP 8.2.29 (cli)
Yes
Today in the morning while i was trying to update Nextcloud
I was trying to update Nextcloud to Version 31.0.8 and got the Error from the Screenshot.
I finally succeeded by manually changing values in the database ( INSERT INTO oc_migrations (app, version) VALUES (‘core’, ‘31000Date20250731062008’); ) but I think it was not the best way. Now everything is working just fine but there are still some background errors.
- Just update to ne newest Nextcloud Version (but maybe my System was just a bit unstable idk)
|Info|updater|\OC\Updater::maintenanceActive: Maintenance mode is kept active|15.08.2025, 12:07:12||
|Info|updater|\OC\Updater::updateEnd: Update successful|15.08.2025, 12:07:12||
|Info|updater|\OC\Updater::finishedCheckCodeIntegrity: Finished code integrity check|15.08.2025, 12:07:12||
|Info|updater|\OC\Updater::startCheckCodeIntegrity: Starting code integrity check...|15.08.2025, 12:06:58||
|Fehlersuche|serverDI|The requested alias "IntegrityCodeChecker" is deprecated. Please request "OC\IntegrityCheck\Checker" directly. This alias will be removed in a future Nextcloud version.|15.08.2025, 12:06:58||
|Info|updater|OC\Repair\Events\RepairInfoEvent: Repair info: Queued background to validate account properties.|15.08.2025, 12:06:58||
|Fehlersuche|no app in context|Exceptiondirty table reads: SELECT `id` FROM `*PREFIX*jobs` WHERE (`class` = :dcValue1) AND (`argument_hash` = :dcValue2) LIMIT 1|15.08.2025, 12:06:58||
|Info|updater|OC\Repair\Events\RepairStepEvent: Repair step: Validate account properties and store phone numbers in a known format for search|15.08.2025, 12:06:58||
|Info|updater|OC\Repair\Events\RepairStepEvent: Repair step: Add cleanup-deleted-users background job|15.08.2025, 12:06:58||
|Info|updater|OC\Repair\Events\RepairStepEvent: Repair step: Remove legacy ".ocdata" file|15.08.2025, 12:06:58||
|Info|updater|OC\Repair\Events\RepairInfoEvent: Repair info: Theming is not used to provide a logo|15.08.2025, 12:06:58||
|Info|updater|OC\Repair\Events\RepairStepEvent: Repair step: Cache logo dimension to fix size in emails on Outlook|15.08.2025, 12:06:58||
|Info|no app in context|core/BackgroundJobs/AppConfigLazyMigration: 0 config values updated|15.08.2025, 12:06:58||
|Fehlersuche|no app in context|Exceptiondirty table reads: SELECT `appid`, `configkey`, `configvalue`, `type`, `lazy` FROM `*PREFIX*appconfig`|15.08.2025, 12:06:58||
|Info|updater|OC\Repair\Events\RepairStepEvent: Repair step: migrate lazy config values|15.08.2025, 12:06:58|
PASTE
PASTE HERE
PASTE HERE
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
