Using the built-in updater I get the error message :
Curl error: SSL certificate problem: certificate has expired
Is this an error on my side or on the side of the nextcloud download. My Let’s Encrypt cerificate seems to be ok…
Tried to create a /tmp directory but this time I get:
The following extra files have been found:
tmp
Nextcloud version : 13.0.6.
Operating system and version: MacOS 13.0.6.
Apache or nginx version (eg, Apache 2.4.25): ???
PHP version : 7.0.30
The issue you are facing: see above
Is this the first time you’ve seen this error? Y
- Start built-in updater
- Start update
- update stops at “Downloading” with
Warning
no app in context
Temporary directory /www/htdocs/w00de87a/nextcloud/tmp/ is not present or writable
2018-10-21T12:34:02+0200
The output of your config.php file
'instanceid' => 'ocimr1v3gqh2',
'passwordsalt' => '...',
'secret' => '...r',
0 => '',
1 => '',
'datadirectory' => '/www/htdocs/.../nextcloud/data',
'overwrite.cli.url' => 'http://.../nextcloud',
'version' => '13.0.6.1',
'dbname' => 'd02b7b39',
'dbhost' => 'localhost',
'dbtableprefix' => 'zNiMI_',
'mysql.utf8mb4' => false,
'dbuser' => '...',
'dbpassword' => '...',
'tempdirectory' => '/www/htdocs/.../nextcloud/tmp/',
'mail_from_address' => 'martin.mikoleit',
'mail_smtpmode' => 'php',
'mail_domain' => 'gmx.de',
'activity_expire_days' => 1,
'theme' => '',
'loglevel' => 2,
'updater.secret' => '...',
Sorry, can't access this file - no root access
