Hi guys,
I was running into a problem while updating from Version 11.0.0 to 11.0.1 using the update App.
I’ve already tried chown -R www-data:www-data /var/www/nextcloud , wich eliminated 80% of the permission errors but the last 2 are here to stay.
Strange thing is, that the updater/ Folder is empty except of two files named index.php and updater.phar .
Can someone please give advice how i could proceed further?
I’m running nextcloud on an Ubuntu 16.04.1 VM.
Kind regards
Michael
Soko
January 19, 2017, 11:32am
#3
try rm /var/www/nextcloud/apps/files_antivirus -r
(after Backup)
or remove at least the two files in the antivirus-folder
then
and resttart the update
Does work ,many thanks.
It’s a shame that you have to delete the antivirus files for that.
Thank you.
Soko
January 19, 2017, 3:38pm
#5
I suppose the two files where locked by the antivirus-app You use…
Possible, but the mentioned folder doesn’t exist.
Maybe the Updater looked there for data that would be needed to update the antivirus app?
