I’ve a problem with update Nextcloud from 20.0.14 to 21.0.7. When I open updater and press update, I get this message:
What files, in which directory I must delete? I can’t find this files.
Thank you very much for help!
Michael
Michael
There are the files/folders index.htm and tmp in your nextcloud directory. You must delete them. Search in /path/to/your/nextcloud
hopefully in the top folder.
Sorry, but there is the problem: I can’t find this files oder directories.
In the root-directory exist this two files:
Do you have any idea?
I solved the problem. I’ve found the files. It was my error, I looked in the wrong Nextcloud-Installation. I’m so sorry
