example
longer
example
here
Nextcloud version (18.0.2): 18.0.2
Operating system and version (eg, Ubuntu 17.04): Ubuntu Linux 18.04.4
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.29
PHP version (eg, 7.1): 7.2.24
The issue you are facing: update to nc version 18.0.3
Update vorbereiten
Log-Level auf “debug” gesetzt
Wartungsmodus eingeschaltet
Reparaturschritt: Repair MySQL collation
Reparaturinformation: All tables already have the correct collation -> nothing to do
Reparaturschritt: Repair SQLite autoincrement
Reparaturschritt: Copy data from accounts table when migrating from ownCloud
Reparaturschritt: Drop account terms table when migrating from ownCloud
Das Datenbankschema wird aktualisiert
Datenbank aktualisiert
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing ‘ALTER TABLE oc_mail_mailboxes DROP sync_token’: SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 767 bytes
PASTE HERE
'instanceid' => 'oc2hunhufqga',
'passwordsalt' => '03yRMunPRZVVW84eHxSIfYjHq2Hs+X',
'secret' => 'fQVHzov9G46ohE4AEQF8s+xYINYMeat1eeW33JJJyWfrE7/c',
0 => 'localhost',
1 => '....',
2 => '.....',
3 => '[fe80::1:50]',
4 => '....',
5 => '....',
'version' => '18.0.3.0',
'overwrite.cli.url' => 'https://.../nextcloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:5432',
'dbuser' => 'nextclouduser',
'dbpassword' => '....',
'theme' => '',
'loglevel' => 2,
PASTE HERE
