I tried to update, but i get the following error:
Downloading updates
Performing updates
Installing template ‘apache2/ncp.conf.sh’…
ERROR: Site nextcloud does not exist!
Error while applying update 1.53.1. Exiting…
Downloading updates
Performing updates
Please post output of
sudo ncp-report
NextcloudPi v1.53.1 is outdated
update to v1.55.3 through 'ncp-config' or type 'sudo ncp-update'
You have new mail.
Last login: Sun Dec 8 04:34:49 2024 from 192.168.250.24
root@nextcloudpi:~# sudo ncp-report
<--! Paste this in GitHub report -->
<details>
<summary>NextcloudPi diagnostics</summary>
Cannot load Zend OPcache - it was already loaded
NextcloudPi version v1.53.1
NextcloudPi image NextCloudPi_03-28-20
OS Armbian 20.05.0-trunk Buster \l . 4.14.222-odroidxu4 (armv7l)
automount yes
USB devices sda
datadir /media/myCloudDrive/ncdata
data in SD no
data filesystem btrfs
data disk usage 586G/932G
rootfs usage 12G/29G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 25.0.8.2
HTTPD service up
PHP service up
MariaDB service up
Redis service up
HPB service up
Postfix service up
Internet check ok
Public IPv4 ***REMOVED SENSITIVE VALUE***
Public IPv6 ***REMOVED SENSITIVE VALUE***
Port 80 closed
Port 443 closed
IP ***REMOVED SENSITIVE VALUE***
Gateway ***REMOVED SENSITIVE VALUE***
Interface enx001e0636e9b3
Certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
Uptime 66days
"trusted_domains": {
"0": "localhost",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"11": "98.185.245.105",
"1": "192.168.250.60",
"2": "home.ryanoleary.com",
"14": "nextcloudpi",
"3": "localhost"
"dbtype": "mysql",
"version": "25.0.8.2",
"overwrite.cli.url": "https:\/\/localhost\/",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"tempdirectory": "\/media\/myCloudDrive\/ncdata\/tmp",
"mail_smtpmode": "smtp",
"mail_smtpauthtype": "LOGIN",
"preview_max_x": "2048",
"preview_max_y": "2048",
"jpeg_quality": "60",
"overwriteprotocol": "https",
"logfile": "\/media\/myCloudDrive\/ncdata\/nextcloud.log",
"loglevel": "2",
"log_type": "file",
"mail_sendmailmode": "smtp",
"mail_smtpauth": 1,
"mail_smtpport": "465",
"mail_smtpsecure": "ssl",
"theme": "",
"data-fingerprint": "eddff727dfbe6e86b7b9d3b30bd93b57",
"memories.exiftool_no_local": true
[Sun Dec 08 04:35:28.195517 2024] [mpm_event:notice] [pid 3626:tid 3626] AH00492: caught SIGWINCH, shutting down gracefully
[Sun Dec 08 04:35:28.339518 2024] [ssl:error] [pid 11960:tid 11960] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: CN=localhost / issuer: CN=localhost / serial: 25671A916C625EA07DBFF6CBED5028D470B6BF72 / notbefore: Mar 28 20:59:46 2020 GMT / notafter: Mar 26 20:59:46 2030 GMT]
[Sun Dec 08 04:35:28.339668 2024] [ssl:error] [pid 11960:tid 11960] AH02604: Unable to configure certificate localhost:4443:0 for stapling
[Sun Dec 08 04:35:28.367312 2024] [ssl:error] [pid 11961:tid 11961] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: CN=localhost / issuer: CN=localhost / serial: 25671A916C625EA07DBFF6CBED5028D470B6BF72 / notbefore: Mar 28 20:59:46 2020 GMT / notafter: Mar 26 20:59:46 2030 GMT]
[Sun Dec 08 04:35:28.367360 2024] [ssl:error] [pid 11961:tid 11961] AH02604: Unable to configure certificate localhost:4443:0 for stapling
[Sun Dec 08 04:35:28.374965 2024] [mpm_event:notice] [pid 11961:tid 11961] AH00489: Apache/2.4.62 (Debian) OpenSSL/1.1.1w configured -- resuming normal operations
[Sun Dec 08 04:35:28.375065 2024] [core:notice] [pid 11961:tid 11961] AH00094: Command line: '/usr/sbin/apache2'
2023-02-24 0:13:32 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2023-02-24 0:13:32 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-02-24 0:13:32 0 [Note] Server socket created on IP: '127.0.0.1'.
2023-02-24 0:13:32 0 [Note] Reading of all Master_info entries succeeded
2023-02-24 0:13:32 0 [Note] Added new Master_info '' to hash table
2023-02-24 0:13:32 0 [Note] /usr/sbin/mysqld: ready for connections.
Version: '10.3.38-MariaDB-0+deb10u1' socket: '/run/mysqld/mysqld.sock' port: 3306 Debian 10
2023-02-24 0:13:32 0 [Note] InnoDB: Buffer pool(s) load completed at 230224 0:13:32
2023-02-24 22:34:28 1238 [Warning] Aborted connection 1238 to db: 'nextcloud' user: 'ncadmin' host: 'localhost' (Got an error reading communication packets)
2023-02-27 4:44:44 5124 [Warning] Aborted connection 5124 to db: 'nextcloud' user: 'ncadmin' host: 'localhost' (Got an error reading communication packets)
2023-02-27 5:06:26 0 [Note] /usr/sbin/mysqld (initiated by: unknown): Normal shutdown
2023-02-27 5:06:26 0 [Note] Event Scheduler: Purging the queue. 0 events
2023-02-27 5:06:26 0 [Note] InnoDB: FTS optimize thread exiting.
2023-02-27 5:06:26 0 [Note] InnoDB: Starting shutdown...
2023-02-27 5:06:26 0 [Note] InnoDB: Dumping buffer pool(s) to /var/lib/mysql/ib_buffer_pool
2023-02-27 5:06:26 0 [Note] InnoDB: Buffer pool(s) dump completed at 230227 5:06:26
2023-02-27 5:06:28 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2023-02-27 5:06:28 0 [Note] InnoDB: Shutdown completed; log sequence number 21305706436; transaction id 63242166
2023-02-27 5:06:28 0 [Note] /usr/sbin/mysqld: Shutdown complete
{"reqId":"L2vj7YkTfmXwYMrXXmuh","level":2,"time":"2024-12-03T18:35:02+00:00","remoteAddr":"","user":"--","app":"dav","method":"","url":"--","message":"Subscription 1 could not be refreshed due to a network error","userAgent":"--","version":"25.0.8.2","exception":{"Exception":"GuzzleHttp\\Exception\\ClientException","Message":"Client error: `GET https://calendar.google.com/calendar/embed?src=roleary%40gmail.com&ctz=America%2FLos_Angeles` resulted in a `401 Unauthorized` response:\n<!DOCTYPE html><style nonce=\"Yj7w5ChJE3794eGWDXXWhQ\">body{height:100%;margin:0;width:100%}@media (max-height:350px){.but (truncated...)\n","Code":401,"Trace":[{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":69,"function":"create","class":"GuzzleHttp\\Exception\\RequestException","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":204,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":153,"function":"callHandler","class":"GuzzleHttp\\Promise\\Promise","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php","line":48,"function":"GuzzleHttp\\Promise\\{closure}","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":248,"function":"run","class":"GuzzleHttp\\Promise\\TaskQueue","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":224,"function":"invokeWaitFn","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":269,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":226,"function":"invokeWaitList","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php","line":62,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"wait","class":"GuzzleHttp\\Promise\\Promise","type":"->"},{"file":"/var/www/nextcloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/CalDAV/WebcalCaching/RefreshWebcalService.php","line":217,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/CalDAV/WebcalCaching/RefreshWebcalService.php","line":89,"function":"queryWebcalFeed","class":"OCA\\DAV\\CalDAV\\WebcalCaching\\RefreshWebcalService","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BackgroundJob/RefreshWebcalJob.php","line":115,"function":"refreshSubscription","class":"OCA\\DAV\\CalDAV\\WebcalCaching\\RefreshWebcalService","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":78,"function":"run","class":"OCA\\DAV\\BackgroundJob\\RefreshWebcalJob","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":64,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BackgroundJob/RefreshWebcalJob.php","line":108,"function":"execute","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCA\\DAV\\BackgroundJob\\RefreshWebcalJob","type":"->"}],"File":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php","Line":113,"message":"Subscription 1 could not be refreshed due to a network error","exception":{},"CustomMessage":"Subscription 1 could not be refreshed due to a network error"}}
{"reqId":"Z1Ji42Xfof458kxEzkJ3jwAAAFQ","level":3,"time":"2024-12-06T02:36:00+00:00","remoteAddr":"192.168.250.1","user":"roleary","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/roleary/Photos/FromPhone/2024/12/PXL_20241206_011443667.MP.jpg","message":"Expected filesize of 5838843 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 4907008 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.29.2","version":"25.0.8.2","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 5838843 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 4907008 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":360,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":297,"message":"Expected filesize of 5838843 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 4907008 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","exception":{},"CustomMessage":"Expected filesize of 5838843 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 4907008 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side."}}
{"reqId":"Z1SgXBH2NItWlJR7wB1JoQAAABQ","level":3,"time":"2024-12-07T19:27:08+00:00","remoteAddr":"192.168.250.1","user":"roleary","app":"no app in context","method":"PUT","url":"/remote.php/dav/uploads/roleary/f2ec693a5d224108aca9068fe6ca25cb/000024","message":"Expected filesize of 40960000 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 10993664 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.29.2","version":"25.0.8.2","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 40960000 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 10993664 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Upload/UploadFolder.php","line":45,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":360,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":297,"message":"Expected filesize of 40960000 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 10993664 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","exception":{},"CustomMessage":"Expected filesize of 40960000 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 10993664 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side."}}
{"reqId":"Z1UyslW17PEpEZjltV-nEAAAAEE","level":3,"time":"2024-12-08T05:46:26+00:00","remoteAddr":"192.168.250.1","user":"roleary","app":"webdav","method":"MOVE","url":"/remote.php/dav/files/roleary/Photos/FromPhone/2024/12/PXL_20241207_183254328.mp4","message":"\"Photos/FromPhone/2024/12/PXL_20241207_183254328.mp4\" is locked, existing lock on file: 3 shared locks","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.29.2","version":"25.0.8.2","exception":{"Exception":"OCP\\Lock\\LockedException","Message":"\"Photos/FromPhone/2024/12/PXL_20241207_183254328.mp4\" is locked, existing lock on file: 3 shared locks","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":802,"function":"changeLock","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":165,"function":"rename","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":153,"function":"setName","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":612,"function":"move","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpMove","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":360,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Files/View.php","Line":2012,"Previous":{"Exception":"OCP\\Lock\\LockedException","Message":"\"files/9052387a9c2aaa73db65f10de418b3f3\" is locked, existing lock on file: 3 shared locks","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Files/Storage/Common.php","line":829,"function":"changeLock","class":"OC\\Lock\\MemcacheLockingProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":632,"function":"changeLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":632,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":2006,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":802,"function":"changeLock","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":165,"function":"rename","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":153,"function":"setName","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":612,"function":"move","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpMove","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":360,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Lock/MemcacheLockingProvider.php","Line":109},"message":"\"Photos/FromPhone/2024/12/PXL_20241207_183254328.mp4\" is locked, existing lock on file: 3 shared locks","exception":{},"CustomMessage":"\"Photos/FromPhone/2024/12/PXL_20241207_183254328.mp4\" is locked, existing lock on file: 3 shared locks"}}
{"reqId":"Z1U_nlW17PEpEZjltV-pxwAAQwg","level":3,"time":"2024-12-08T06:41:55+00:00","remoteAddr":"192.168.250.1","user":"roleary","app":"index","method":"GET","url":"/index.php/apps/photos/api/v1/preview/242814?etag=4a23aa7128e7501b9f12c6070312b2d5&x=64&y=64","message":"Could not create folder","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"25.0.8.2","exception":{"Exception":"OCP\\Files\\NotPermittedException","Message":"Could not create folder","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Files/AppData/AppData.php","line":147,"function":"newFolder","class":"OC\\Files\\Node\\Folder","type":"->"},{"file":"/var/www/nextcloud/lib/private/Preview/Storage/Root.php","line":74,"function":"newFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/var/www/nextcloud/lib/private/Preview/Generator.php","line":581,"function":"newFolder","class":"OC\\Preview\\Storage\\Root","type":"->"},{"file":"/var/www/nextcloud/lib/private/Preview/Generator.php","line":137,"function":"getPreviewFolder","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Preview/Generator.php","line":114,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/nextcloud/lib/private/PreviewManager.php","line":185,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/var/www/nextcloud/apps/photos/lib/Controller/PreviewController.php","line":162,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/var/www/nextcloud/apps/photos/lib/Controller/PreviewController.php","line":128,"function":"fetchPreview","class":"OCA\\Photos\\Controller\\PreviewController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"index","class":"OCA\\Photos\\Controller\\PreviewController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1048,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/Files/Node/Folder.php","Line":165,"CustomMessage":"--"}}
</details>
This worked for me:
perfect
worked for me too. many thanks to share your solution
