Nextcloud version : 20.0.9
Operating system and version: Centos7
Apache: httpd-2.4.6-97.el7.centos.x86_64
PHP version: PHP 7.3.x
Hello, after the most recent update of my Nextcloud instance there is this message in my overview section:
The old server-side-encryption format is enabled. We recommend disabling this. For more details see the documentation.
When I run the command mentioned in the documentation, “sudo -u apache php occ encryption:scan:legacy-format” it gives me errors, saying that some files do not have proper headers.
- What does that tell me?
- Can this be ignored?
- Can I safely disable legacy encryption?
- How can I find out what that is supposed to mean?
- Is there detailed documentation so I can help myself?
The official “Documentation”, I would call this a note rather, doesn’t help: https://docs.nextcloud.com/server/20/admin_manual/configuration_files/encryption_migration.html#encryption-migration.
Maybe someone with the proper background might elaborate on this?
- Update NC (at the time of writing this, to version 20.0.9)
- Navigate to (using a NC admin account): Administration → Overview
- Find the message: The old server-side-encryption format is enabled. We recommend disabling this. For more details see the documentation.
- Run sudo -u apache php occ encryption:scan:legacy-format
- Be confused about what to do with this message???
Then run said command “occ encryption:scan:legacy-format” the only output it provides me is:
[/path/to/filename] does not have a proper header
'encryption.legacy_format_support' => true,
'encryption.key_storage_migrated' => false,
Thx <3
