I updated my docker-compose installation with
docker-compose pull; docker-compose up
after that upgrade the database is not working any more with those errors:
[Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.8.3+maria~jammy started.
[Note] [Entrypoint]: Switching to dedicated user 'mysql'
[Note] [Entrypoint]: MariaDB upgrade (mariadb-upgrade) required, but skipped due to $MARIADB_AUTO_UPGRADE setting
[Note] Using unique option prefix 'key_buffer' is error-prone and can break in the future. Please use the full name 'key_buffer_size' instead.
[Note] mariadbd (server 10.8.3-MariaDB-1:10.8.3+maria~jammy-log) starting as process 1 ...
[Warning] You need to use --log-bin to make --binlog-format work.
[Note] InnoDB: Compressed tables use zlib 1.2.11
[Note] InnoDB: Number of transaction pools: 1
[Note] InnoDB: Using crc32 + pclmulqdq instructions
[Warning] mariadbd: io_uring_queue_init() failed with ENOSYS: check seccomp filters, and the kernel version (newer than 5.1 required)
[Warning] InnoDB: liburing disabled: falling back to innodb_use_native_aio=OFF
[Note] InnoDB: Initializing buffer pool, total size = 128.000MiB, chunk size = 2.000MiB
[Note] InnoDB: Completed initialization of buffer pool
[ERROR] InnoDB: File ./ib_logfile0 was not found
[ERROR] InnoDB: Plugin initialization aborted with error Generic error
[Note] InnoDB: Starting shutdown...
[ERROR] Plugin 'InnoDB' init function returned error.
[ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
[Note] Plugin 'FEEDBACK' is disabled.
[Warning] 'innodb-buffer-pool-instances' was removed. It does nothing now and exists only for compatibility with old my.cnf files.
[Warning] 'innodb-large-prefix' was removed. It does nothing now and exists only for compatibility with old my.cnf files.
[Warning] 'innodb-file-format' was removed. It does nothing now and exists only for compatibility with old my.cnf files.
[Warning] 'default-authentication-plugin' is MySQL 5.6 / 5.7 compatible option. To be implemented in later versions.
[ERROR] Unknown/unsupported storage engine: InnoDB
[ERROR] Aborting
This is my docker file:
version: '3'
services:
  db:
    image: mariadb
    command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW --skip-innodb-read-only-compressed --innodb_read_only_compressed=OFF
    restart: always
    volumes:
      - /var/kunden/docker/nc/volumes/mysql:/var/lib/mysql
      - /var/kunden/docker/nc/myconfig.cnf:/etc/mysql/conf.d/myconfig.cnf:ro
    environment:
      - MYSQL_ROOT_PASSWORD=***
      - MYSQL_PASSWORD=***
      - MYSQL_DATABASE=nextcloud
      - MYSQL_USER=nextcloud
  app:
    image: nextcloud:24
    build:
      context: .
      dockerfile: Dockerfile
    ports:
      - 8085:80
    links:
      - db
    volumes:
      - /var/kunden/docker/nc/volumes/html:/var/www/html
    restart: always
