Nextcloud version : 13.0.4
Operating system and version : Debian 9
Apache or nginx version : nginx 1.10.3
PHP version : 7.0
I have upgrade Nextcloud from 13.0.1 to 13.0.4, and I have strange messages in the Logging panel:
|Error|PHP|unlink(/tmp/oc_tmp_ikmXSR-.crt): Operation not permitted at /var/www/nextcloud/lib/private/legacy/helper.php#224|2018-06-25T13:43:31-0700|
|Error|PHP|unlink(/tmp/oc_tmp_ikmXSR): Operation not permitted at /var/www/nextcloud/lib/private/legacy/helper.php#224|2018-06-25T13:43:31-0700|
I understand that there can be a problem of permission but I really don’t know what and where. Everything else seem to work.
Any idea ?
Here is the output of my config.php
'instanceid' => 'lololol',
'passwordsalt' => 'lololol',
'secret' => 'lololol+Vo+er5IMDb6jpvE5',
0 => 'localhost',
1 => 'cloud.lololol.org',
'datadirectory' => '/home/data/cloud',
'overwrite.cli.url' => 'localhost',
'version' => '13.0.4.0',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'lololol',
'redis' => array (
'host' => 'localhost',
'port' => 6379,
'theme' => '',
'loglevel' => 2,
'apps_paths' =>
0 =>
'path' => '/var/www/nextcloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/www/nextcloud/apps2',
'url' => '/apps2',
'writable' => true,
'updater.secret' => 'lololol',
Thanks !
