example
longer
example
here
Nextcloud version (eg, 18.0.2): 18.0.3
Operating system and version (eg, Ubuntu 20.04): ubuntu-server 18.04.4
Apache or nginx version (eg, Apache 2.4.25): NGinx 1.17.10
PHP version (eg, 7.1): 7.3
The issue you are facing: User Quota values set by the admin are not shown by NC
e.g. you set 10 GB / user - you only see the bar that shows how many MB are used but not e.g. 1GB / 10 GB used as in earlier NC versions
Irritating for the admin not to see how much Quota a user has been added
- give a user a quota
- let the user load up files and use the quota
- check the values the admin can see in it’s control panel
- check my screenshot
at upper right side of the menue-bar) for similar problems before posting your next thread? that would be cool
