Update 13.0.6 to 14.0.2 instead of 13.0.7 with some bugs.
Anyway, I have got three bugs left I cannot fix with:
News app does not work with internal server error and then a wheel.
Error messages in log every seconds:
Error PHP You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18
I have updated php-intl et php to php-7.2 and php7.2-intl with restart to no avail. -
Cron.php does not work and I have to set it to Ajax.
Finally, today update to 14.0.3 was proposed in the web updater but it does not work (“Unable to start the update system, please try to update manually”). I have tried in Terminal ( sudo -u www-data php updater.phar ) but I got,
Nextcloud Updater - version: v14.0.2RC2-1-g21ab216
Current version is 14.0.2.
PHP Fatal error: Uncaught Error: Call to undefined function NC\Updater\curl_init() in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php:440…
Have you got some clues or I have to downgrade?
ARMBIAN 5.60 stable Debian GNU/Linux 9 (stretch) 4.14.69-odroidxu4
PHP 7.2.10-1+0~20181002090802.4+stretch~1.gbpb6e829 (cli) (built: Oct 2 2018 09:08:03) ( NTS )
nginx version: nginx/1.10.3
Laurent
