Unable to Paste from System into Nextcloud Office
Same behaviour for me also.
Just updated this morning to Collabora Online - Built-in CODE Server Version 25.4.504 and the copy/paste works from within the document but doesn’t work from outside
When using ctrl+v, the page flashes but nothing pasted. If you let the keys ctrl+v down for some time then it eventually works but paste several occurrence of the text
It works on an Android mobile device, but it does not work on a Macbook ( any browser).
Has anyone tried on the iOS mobile app and Windows?
I have the same issue. Pasting from within the document works fine, but not from the system. I can paste perfectly well into other applications such as Nextcloud notes, but not Collabora with CODE.
I did remove the app Collabora Online Builtin CODE and installed the Docker-instance of Collabora Online CODE server - works like a charm now.
Copy/paste issue should be https://github.com/CollaboraOnline/richdocumentscode/issues/323 ticket that has the fix for the following Builtin CODE release, I assume 25.04.60x.
