At my work, we are installed a nextcloud instance to put to file and make a POC.
We used a dedicated web server with NGINX in a DMZ and an internal MYSQL Server working on a specific port (8010).
Installation works successfully with dbserver:8010 but after installation, I got a 504 error.
After logging firewall, it appears Nextcloud tried to connect DB with 3306 port …
I tried to specify ‘dbport’ => ‘8010’ but it doesn’t work.
I tried to specify ‘dbhost’ => ‘mydbserver:8010’ without a dbport. With that config, I got a strange thing : URL is redirecting to : nextcloud.xxx.com/index.php/index.php
I tried nextcloud 14 and 15 with same issue.
Do someone already have this kind of issue ???
Thanks a lot for your answer
//Fabien
edit : correcting quote on dbhost
