[details="Support intro”]
- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
When adding Remote external local or smb USB HDD from within the admin account, I receive " Confirm your password”
"This action requires authentication”
I have tried all passwords that I have set whilst installing Nextcloud with no results ie Nextcloud admin
Nextcloud user
samba password
MySQL root password
all fail authentication
Please can anyone offer any advice….
Thanks
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
30.0.4
Raspberry pi lite 64bit Bookworm
Apache/2.4.62 (Debian)
replace me
- PHP version (e.g, 8.3):
8.3
yes
immediately after new installation
replace me
- `no
- log in as admin
- select administrative settings
- external storage
- set Folder Name
- set external storage type smb/cifs
- set Hostname
- set samba share name
- set remote folder
- set samba username and password
- Tick available to all people
- click on save
12 Confirm password now pops up and fails all known passwords
{"reqId":"YH7fRQaB90f2M5vBjJJ8","level":2,"time":"2025-01-07T09:41:45+00:00","remoteAddr":"192.168.1.4","user":"--","app":"core","method":"GET","url":"/nextcloud/remote.php/dav/files/admin/Joplin/info.json","message":"Login failed: 'admin' (Remote IP: '192.168.1.4')","userAgent":"Joplin/1.0","version":"30.0.4.1","data":{"app":"core"},"id":”677d7e25dbd68”}
PASTE
sudo cat error.log
[Tue Jan 07 00:00:07.527721 2025] [mpm_prefork:notice] [pid 19931:tid 19931] AH00163: Apache/2.4.62 (Debian) configured -- resuming normal operations
[Tue Jan 07 00:00:07.527808 2025] [core:notice] [pid 19931:tid 19931] AH00094: Command line: '/usr/sbin/apache2’
[Tue Jan 07 12:09:44.576821 2025] [access_compat:error] [pid 39421:tid 39421] [client 192.168.1.1:52694] AH01797: client denied by server configuration: /var/www/nextcloud/data/.ncdata
[Tue Jan 07 17:54:20.507422 2025] [access_compat:error] [pid 44135:tid 44135] [client 192.168.1.1:43710] AH01797: client denied by server configuration: /var/www/nextcloud/data/.ncdata
'instanceid' => ‘xxxxxxxxxxxxw’,
'passwordsalt' => ‘xxxxxxxxxxxx’,
'secret' => ‘xxxxxxxxxxxxxxxxxxxxxx’,
0 => ‘192.168.1.1’,
'datadirectory' => '/var/www/nextcloud/data’,
'dbtype' => ‘mysql’,
'version' => ’30.0.4.1’,
'overwrite.cli.url' => 'http://192.168.1.1/nextcloud’,
'dbname' => ‘nextclouddb’,
'dbhost' => ‘localhost’,
'dbport' => ‘’,
'dbtableprefix' => ‘oc_’,
'dbuser' => ‘nextclouduser’,
'dbpassword' => ‘123x’,
- activity: 3.0.0
- app_api: 4.0.3
- bruteforcesettings: 3.0.0
- calendar: 5.0.8
- circles: 30.0.0
- comments: 1.20.1
- contacts: 6.1.2
- contactsinteraction: 1.11.0
- dashboard: 7.10.0
- dav: 1.31.1
- federation: 1.20.0
- files: 2.2.0
- files_downloadlimit: 3.0.0
- files_external: 1.22.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- firstrunwizard: 3.0.0
- logreader: 3.0.0
- mail: 4.1.1
- notes: 4.11.0
- notifications: 3.0.0
- oauth2: 1.18.1
- password_policy: 2.0.0
- photos: 3.0.2
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- richdocuments: 8.5.3
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- spreed: 20.1.1
- support: 2.0.0
- survey_client: 2.0.0
- systemtags: 1.20.0
- text: 4.1.0
- theming: 2.5.0
- updatenotification: 1.20.0
- user_status: 1.10.0
- viewer: 3.0.0
- weather_status: 1.10.0
- workflowengine: 2.12.0
Disabled: - admin_audit: 1.20.0
- encryption: 2.18.0
- suspicious_login: 8.0.0
- twofactor_totp: 12.0.0-dev
- user_ldap: 1.21.0
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
