UFW for (docker) NextCloud AIO
I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
I realized, I have run NextCloud AIO (in docker) for almost 2 years with UFW disabled on my server.
Now, wanting to enable it, I’m unsure as of what ports exactly must be allowed, and wether from anywhere or local only
Is there a resource that outlines optimal UFW settings for a nextcloud install (which has CALLS enabled, I think this is important as far I saw, since it uses its own port)
I would appreciate any hint, in the net I could only find the obvious ports + 3478 (turn) and 8080 (aio) (udp and tcp), but not whether they should be allow from anywhere or restricted (specially 3478 and 8080 is what I am wondering about)
8080 is the AIO interface. It’s not generally publicly exposed.
Specifics can depend on other aspects of your deployment.
https://github.com/nextcloud/all-in-one#which-ports-are-mandatory-to-be-open-in-your-firewallrouter
