Pls help a noob. I’m trying to install nextcloud on a Hetzner VPS running Ubuntu 19.04 with an existing nginx installation. I have followed the guide here and all has gone well until I try to access my server using at ‘myserver.co.uk/nextcloud’ and I just get a 404 screen.
nginx is working for other applications setup in the config file as other locations, it’s just this one.
My install directory is ‘/usr/share/nginx/nextcloud’ which is set to user & group ‘www-data’. My nginx config looks like the below and is in the location: ‘/etc/nginx/sites-enabled/reverse’ I’d really appreciate any help you can give o help me access and start setting up this application which seems to be one of the most used self-hosted apps!
When I look at the nginx log I see the error:
2019/10/29 16:21:23 [error] 2374#2374: *75 open() "/usr/share/nginx/nexcloud/404.html" failed (2: No such file or directory), client: 162.158.154.214, server: , request: "GET /nextcloud HTTP/1.1",$
Really, really appreciate any help… I’ve been trying to solve ot for the last few days myself. But have realised I now need help.
nginx file:
upstream php-handler {
server 127.0.0.1:9000;
# server unix:/var/run/php/php7.2-fpm.sock;
server {
listen 80 default_server;
listen [::]:80 default_server;
server_name myserver.co.uk 195.201.xx.xxx;
return 301 https://$server_name$request_uri;
server {
# SSL configuration
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
include /etc/nginx/snippets/strong-ssl.conf;
ssl_certificate /etc/letsencrypt/live/myserver.co.uk/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/myserver.co.uk/privkey.pem;
error_log /var/log/nginx/myserver.co.uk.error.log;
# Root location
root /usr/share/nginx/nexcloud/;
# Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html;
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# could take several months.
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
# Basic Auth to protect the site
auth_basic "Restricted";
auth_basic_user_file /etc/nginx/.htpasswd;
# Change the client side error pages (4xx) to prevent some information disclosure
error_page 401 403 404 /404.html;
# First attempt to serve request as file, then as directory,
# then fall back to displaying a 404.
# location / {
# try_files $uri $uri/ =404;
# Deny access to .htaccess files, if Apache's document
# root concurs with nginx's one
location ~ /\.ht {
deny all;
# Let's Encrypt Webroot plugin location -- allow access
location ^~ /.well-known/acme-challenge/ {
auth_basic off;
autoindex on;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#NextCloud
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
#pagespeed off;
# error_page 403 /core/templates/403.php;
# error_page 404 /core/templates/404.php;
location /nextcloud {
rewrite ^ /nextcloud/index.php;
location ~ ^\/nextcloud\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/nextcloud\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^\/nextcloud\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+)\.php(?:$|\/) {
fastcgi_split_path_info ^(.+?\.php)(/.*|)$;
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
# Avoid sending the security headers twice
# Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^\/nextcloud\/(?:updater|oc[ms]-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js, css and map files
location ~ ^\/nextcloud\/.+[^\/]\.(?:css|js|woff2?|svg|gif|map)$ {
try_files $uri /nextcloud/index.php$request_uri;
add_header Cache-Control "public, max-age=15778463";
# Add headers to serve security related headers (It is intended
# to have those duplicated to the ones above)
# into this topic first.
access_log off;
location ~ ^\/nextcloud\/.+[^\/]\.(?:png|html|ttf|ico|jpg|jpeg|bcmap)$ {
# Optional: Don't log access to other assets
access_log off;
.... next location
