I’m a total newcomer to Nextcloud. I think it rocks. So far I have used Nextcloud as an end user, accessing from Android a Nextcloud instance provided by my ISP.
So far, so good. Both web access to my file storage (using a url like https://server32.myisp.com) and using the Nextcloud client from Play Store work fine (I had to select “custom server”, enter server32(dot) myisp(dot) com as server name and the user name and password that I type when accessing through the web browser) .
But now I want to see if I can access these files over webdav.
This is where things get confusing.
The web documentation speaks about a webdav://username@hostname.com/nextcloud/… url format.
On the contrary the Android apps I have tried for webdav access ask just for url, protocol, and port number, defaulting to port 443
One of these, webdav explorer, asks just for “hostname” and has “http” as pre filled protocol.
Another one I tried, the Solid Explorer file manager for Android, failed miserably to connect. That makes me think the webdav user name might be different from the one I’m trying to enter. See below as to why I ask this…
To confuse me even more, when I access my Nextcloud instance from the web at https://server52.myisp.com I must enter as username my email address, say user@isp.com, and my custom chosen password as password.
But when I do get connected with the Nextcloud android app, if I click on the icon next to my user name, I get a long username that looks like a hashed version of my username, something like
Ab2F05abba223300ad2320@server52.myisp.com
So which should I enter as username for webdav access? The “normal” username I enter on the web access login page, or this long username in the format displayed?
TIA for any hints…
