Trying to switch Nextcloud pre built VM to HTTP from HTTPS
example
longer
example
here
Nextcloud version (eg, 29.0.5): 29.0.4
Operating system and version (eg, Ubuntu 24.04): Ubuntu 22.04.4 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.52
PHP version (eg, 8.3): 8.3
The issue you are facing: I am implementing reverse proxy with Caddy, and trying to switch Nextcloud from HTTPS to HTTP and let Caddy handle SSL.
  1. I am using HanssonIT pre-built VM, and modifying config.php
  2. Tried adding ‘overwriteprotocol’ => ‘http’ and updated my ‘overwrite.cli.url’ from the dynamic DNS name it’s always been to either localhost or the ip address of the server.
Can't login to interface, so cannot collect.
  'passwordsalt' => 'REDACTED',
  'secret' => 'REDACTED',
    0 => 'DYNAMIC DNS',
    1 => 'NEW DOMAIN BEHIND CADDY',
    2 => 'LOCAL IP OF SERVER',
  'datadirectory' => '/mnt/ncdata',
  'dbtype' => 'pgsql',
  'version' => '29.0.4.1',
  'overwrite.cli.url' => 'DYNAMIC DNS',
  'overwriteprotocol' => 'http',
  'dbname' => 'nextcloud_db',
  'dbhost' => 'localhost',
  'dbuser' => 'REDACTED',
  'dbpassword' => 'REDACTED',
  'instanceid' => 'REDACTED',
  'log_type' => 'file',
  'loglevel' => '2',
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'mail_smtpmode' => 'smtp',
  'remember_login_cookie_lifetime' => '1800',
  'log_rotate_size' => '10485760',
  'trashbin_retention_obligation' => 'auto, 60',
  'versions_retention_obligation' => 'auto, 180',
  'activity_expire_days' => '120',
  'redis' =>
    'port' => 0,
    'timeout' => 0.5,
 'dbindex' => 0,
    'password' => 'REDACTED',
  'default_phone_region' => 'us',
  'logtimezone' => 'US/Central',
  'enable_previews' => true,
  'enabledPreviewProviders' =>
    11 => 'OC\\Preview\\PNG',
    12 => 'OC\\Preview\\JPEG',
    13 => 'OC\\Preview\\GIF',
    14 => 'OC\\Preview\\BMP',
    16 => 'OC\\Preview\\MP3',
    17 => 'OC\\Preview\\TXT',
  'preview_max_x' => 2048,
  'preview_max_y' => 2048,
  'jpeg_quality' => 60,
  'has_rebuilt_cache' => true,
  'mail_smtpsecure' => 'ssl',
  'mail_smtphost' => 'REDACTED',
  'mail_smtpport' => '465',
  'mail_smtpauthtype' => 'PLAIN',
  'mail_smtpauth' => 1,
  'mail_from_address' => 'REDACTED',
  'mail_domain' => 'REDACTED',
  'mail_smtpname' => 'REDACTED',
  'mail_smtppassword' => 'REDACTED',
  'memories.exiftool_no_local' => true,
  'memories.vod.path' => '/var/www/nextcloud/apps/memories/bin-ext/go-vod-amd64',
  'memories.db.triggers.fcu' => true,
  'app_install_overwrite' =>
    0 => 'otpmanager',
    1 => 'news',
Or, am I overthinking this, and is there a way to just use Caddy to pass port 443 to Nextcloud, and keep Nextcloud handling it’s SSL Cert renewal? For that I’ve have to change it to a different domain, but is that even possible to just use a pass through instead of trying to reverse forced HTTPS to HTTP?
this is my caddy config for nextcloud
https://nextcloud.REDACTED.XX {
	header Strict-Transport-Security max-age=31536000;
    reverse_proxy nextcloud:443 {
        transport http {
            tls
            tls_insecure_skip_verify
and my overwrite.cli.url points to my domain i set for nextcloud or in this case the one at the top of the caddy config https://nextcloud.REDACTED.XX
That is amazing! That works perfectly against my Clone VM.
So my next question, with this setup, I’m assuming I will need to change Nextcloud / Certbot to obtain a SSL cert against the new domain? Because my pre built VM is doing it’s own SSL Cert. Or, is Nextcloud just inheriting the SSL Cert obtained by Caddy?
Right now, if I check the SSL Cert against my clone, it appears to be the one obtained by Caddy.
From now on the reverse proxy will handle the certs no need for the local instance to have its own certs.
After all that’s what a reverse proxy is for.
Thanks for the help! I really appreciate the Caddy block
