A had frontend nginx like a proxy_pass to backend apache. On this apache configured nextcloud.
When i connect to httpS://domain.com , first nextcloud say add trusted domain and after that
works redirect to IP_backend/index.php/login?redirect_url=/index.php/apps/files/
And nextcloud work. Help me! I want see httpS://domain.com
nginx frontend:
server {
listen 443 ssl;
server_name cloud.node.r;
access_log /var/log/nginx/xxx.log;
error_log /var/log/nginx/cxxx_error.log;
proxy_read_timeout 12h;
proxy_send_timeout 12h;
ssl_certificate /etc/letsencrypt/live/xxx/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/xxx/privkey.pem;
ssl_dhparam /etc/letsencrypt/live/xxx/dhparam.pem;
location / {
allow all;
proxy_pass http://10.0.0.100:80;
apache backend:
<VirtualHost *:80>
DocumentRoot /var/www/html/nextcloud/
ServerName cloud.profnode.ru
ErrorLog /var/log/apache2/cloud.profnode.ru_error.log
CustomLog /var/log/apache2/cloud.profnode.ru_access.log combined
<Directory /var/www/html/nextcloud/>
Options +FollowSymlinks
AllowOverride All
Dav off
SetEnv HOME /var/www/html/nextcloud
SetEnv HTTP_HOME /var/www/html/nextcloud
