example
longer
example
here
Nextcloud version 23.0.11
Operating system and version Ubuntu 20.04
Apache or nginx version Apache 2.4.25
PHP version 7.4
I can sync large files without a problem however when I create a link on the NC web interface and attempt to download using that link the down load is truncated to less that half the size of the file that was synced. If I use the NC web interface to download the same file the result is the same; the file is truncated.
Is this the first time you’ve seen this error? No. I had this problem using NC 20 also
- Sync a large file from my desktop (ubuntu 20.04) using the client
- Open the NC web interface, get the link to the file, email it to myself, click the link and download.
- Open the downloaded file and find that it has been truncated
[no app in context] Warning: Could not detect any host in http:///cloud1/data/htaccesstest.txt
POST /cloud1/index.php
from 209.248.116.225 at 2022-11-29T17:53:05+00:00
[PHP]
display_errors = Off
max_execution_time = 3600
max_input_time = 3600
max_input_vars = 1000
memory_limit = 4096M
post_max_size = 16G
session.gc_maxlifetime = 1440
session.save_path = "/var/cpanel/php/sessions/ea-php73"
upload_max_filesize = 16G
zlib.output_compression = Off
output_buffering = 0
PASTE HERE
PASTE HERE
PASTE HERE
