Hello there ,
I have an issue with my nextcloud server since yesterday I’ve tried to access it but it keeps showing me this error message:
Ihr Datenverzeichnis ist ungültig. Stellen Sie sicher, dass eine Datei “.ocdata” im Wurzelverzeichnis des data-Verzeichnisses existiert. Your data directory is not writable Berechtigungen können zumeist korrigiert werden indem dem Web-Server Schreibzugriff auf das Wurzel-Verzeichnis eingeräumt wird. Siehe auch https://docs.nextcloud.com/server/19/go.php?to=admin-dir_permissions.
Nextcloud version (19.0.2.2):
Operating system and version (Raspian GNU Linux 10):
The issue occured after a power outage, is that a conincidence ?
Further logs and information:
nexcloud log:
NextCloudPi diagnostics
{“reqId”:“dD35tA19UzmJg4gZHhCF”,“level”:2,“time”:“2020-10-31T13:40:06+00:00”,“remoteAddr”:"",“user”:"–",“app”:“no app in context”,“method”:"",“url”:"–",“message”:“Temporary directory /media/myCloudDrive/ncdata/tmp is not present or writable”,“userAgent”:"–",“version”:“19.0.2.2”}
Nextcloud is in maintenance mode - no apps have been loaded
{„reqId":“dD35tA19UzmJg4gZHhCF”,“level”:3,“time”:“2020-10-31T13:40:07+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:"fopen(/media/myCloudDrive/ncdata/
data_dir_writability_test_5f9d6937218c3.tmp): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/legacy/OC_Util.php#790",“userAgent”:"–",“version”:“19.0.2.2”}
{“reqId”:“dD35tA19UzmJg4gZHhCF”,“level”:3,“time”:“2020-10-31T13:40:07+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“fopen(/media/myCloudDrive/ncdata/nextcloud.log): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/Log/File.php#84”,“userAgent”:"–",“version”:“19.0.2.2”}
NextCloudPi version v1.31.0
Nextcloud configuration
{“reqId”:“F05B6APXkoihqIu5ORDc”,“level”:2,“time”:“2020-10-31T13:40:12+00:00”,“remoteAddr”:"",“user”:"–",“app”:“no app in context”,“method”:"",“url”:"–",“message”:“Temporary directory /media/myCloudDrive/ncdata/tmp is not present or writable”,“userAgent”:"–",“version”:“19.0.2.2”}
{„reqId":“F05B6APXkoihqIu5ORDc”,“level”:3,“time”:“2020-10-31T13:40:12+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:"fopen(/media/myCloudDrive/ncdata/
data_dir_writability_test_5f9d693ca06a9.tmp): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/legacy/OC_Util.php#790“,“userAgent”:"–",“version”:“19.0.2.2”}
Your data directory is invalid
Ensure there is a file called “.ocdata” in the root of the data directory.
Permissions can usually be fixed by giving the webserver write access to the root directory. See https://docs.nextcloud.com/server/19/go.php?to=admin-dir_permissions.
Exception: Environment not properly prepared. in /var/www/nextcloud/lib/private/Console/Application.php:168
Stack trace:
#0 /var/www/nextcloud/console.php(99): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#1 /var/www/nextcloud/occ(11): require_once(’/var/www/nextcl…’)
#2 {main}
{“reqId”:“F05B6APXkoihqIu5ORDc”,“level”:3,“time”:“2020-10-31T13:40:12+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“fopen(/media/myCloudDrive/ncdata/nextcloud.log): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/Log/File.php#84”,“userAgent”:"–",“version”:“19.0.2.2”}
[Sat Oct 31 13:24:04.810572 2020] [authz_host:error] [pid 928:tid 2764440608] [client 192.168.178.73:49440] AH01753: access check of ‘localhost’ to /img/settings-white.svg failed, reason: unable to get the remote host name, referer: https://nextcloudpi.local:4443/css/ncp.css
[Sat Oct 31 13:25:13.657207 2020] [proxy_fcgi:error] [pid 928:tid 2764440608] [client 192.168.178.73:49440] AH01067: Failed to read FastCGI header
[Sat Oct 31 13:25:13.657343 2020] [proxy_fcgi:error] [pid 928:tid 2764440608] (104)Connection reset by peer: [client 192.168.178.73:49440] AH01075: Error dispatching request to :4443:
Sat Oct 31 13:25:13.850357 2020] [mpm_event:notice] [pid 927:tid 3070157328] AH00491: caught SIGTERM, shutting down
[Sat Oct 31 13:25:34.855437 2020] [ssl:warn] [pid 740:tid 3069248016] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Sat Oct 31 13:25:34.892156 2020] [ssl:warn] [pid 892:tid 3069248016] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Sat Oct 31 13:25:34.897979 2020] [mpm_event:notice] [pid 892:tid 3069248016] AH00489: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1d configured – resuming normal operations
[Sat Oct 31 13:25:34.898092 2020] [core:notice] [pid 892:tid 3069248016] AH00094: Command line: ‚/usr/sbin/apache2’
tail: cannot open ‘/media/myCloudDrive/ncdata/nextcloud.log’ for reading: No such file or directory
The output of my config.php file
?php
'passwordsalt' =>xxx ,
'secret' => xxx,
0 => 'xxx',
11 => 'xxx',
1 => 'xxx',
5 => 'xxx.local',
7 => 'xxx',
8 => 'xxx',
12 => xxx,
'datadirectory' => '/media/myCloudDrive/ncdata',
'version' => '19.0.2.2',
'overwrite.cli.url' => xxx,
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbport' => 'xxx',
'dbuser' =>xxx,
'dbpassword' => xxx,
'instanceid' => 'oct62j5rv71k',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'password' => '1dDX1SR5uGxhm07FhShqJUvjXNO+cSRO2YAMiEkpZJw=',
'tempdirectory' => '/media/myCloudDrive/ncdata/tmp',
'mail_smtpmode' => 'sendmail',
'mail_from_address' => 'admin',
'mail_domain' => 'xxx',
'preview_max_x' => '2048',
'preview_max_y' => '2048',
'jpeg_quality' => '60',
'maintenance' => true,
'logfile' => '/media/myCloudDrive/ncdata/nextcloud.log',
It would be great if someone could help me here :)
