example
longer
example
here
Nextcloud version: 16.0.3.0
Operating system and version: Fedora 31
Apache or nginx version: Apache/2.4.41 (Fedora)
PHP version: PHP 7.3.13
When attempting to follow this guide to set up LDAP with FreeIPA, when modifying my User filter, the “groups” drop-down is greyed out. I’ve spotted a few other support articles and bug trackers like this one which suggest that the “memberOf” LDAP directive is responsible. In fact, when I manually enter an ldapUserFilter of (memberOf=cn=nextcloudusers,cn=groups,cn=accounts,dc=homelab,dc=local)
, Nextcloud freezes up and I see a “Gateway Timeout” after a while.
The funny part is, I’ve had a different instance of Nextcloud working with FreeIPA in the past. I set it up using the linked guide, too. But before I wiped my hard drives, I forgot to save my configs and stuff for Nextcloud. I know that “memberOf” should work, because it’s worked in a different instance. I don’t understand why Nextcloud now freezes when I try to manually specify it.
'instanceid' => '*',
'passwordsalt' => '*',
'secret' => '*',
0 => 'dragoncloud.homelab.local',
'version' => '16.0.3.0',
'overwrite.cli.url' => 'https://dragoncloud.homelab.local',
'dbname' => 'nextcloud',
'dbhost' => 'dragondb.homelab.local',
'dbuser' => 'nextcloudusr',
'dbpassword' => '*',
'ldapIgnoreNamingRules' => false,
'log_type' => 'syslog',
'memcache.local' => '\OC\Memcache\APCu',
