Trouble with 2-Way Sync in Nextcloud v3.30.0 - Notes Not Updating Properly
Hey everyone,
I recently updated the Nextcloud Android app to version 3.30.0 (.APK file from GitHub) and was super excited to try out the new 2-way sync feature. However, I’m a bit unsure if I’m using it correctly, so I wanted to clarify a few things.
My main use case is syncing a folder to my tablet and using that synced folder as the input folder for note-taking apps like Obsidian or Logseq. I selected the folder with the new Sync checkbox, and in Obsidian, I pointed it to the folder in Android/media/com.nextcloud.client/..., where it should be syncing to.
The issue I’m running into is that if I update a note, the changes seem to get discarded. Also, any new notes or folders I create aren’t being recognized by the Nextcloud app.
Is this a bug, or is this how the feature is supposed to work? I was under the impression that only external folders (outside of the Nextcloud app’s data directory, i.e. Android/media/com.nextcloud.client/...) wouldn’t sync properly.
Thanks in advance for the clarification! :blush:
Hmm, in this case logs would be really help to better understand any errors. Could you please check for them as admin.
Hey,
sure, could you tell me where I can find the logs? What exactly do you need? Thank you!
To clarify:
I meant when I update/create a new note/folder in e.g. Obsidian, not in the native Nextcloud app; in case that wasn’t clear.
Logs are available to the admin user. Check the top right of the screen after logging in and there will be an admin panel, which includes access to the logs: warnings, errors, etc.
Or you can try from the commandline Logging — Nextcloud latest Administration Manual latest documentation
Hey,
do you actually need the logs from the web interface/server? I thought that was separate from the mobile app, so I’m a bit confused—sorry about that.
Also, there’s nothing in the server logs. No errors/warnings/… during the period I tested the new feature.
What I have noticed is that when I open the details menu for the source folder and manually click “Sync,” it starts the sync process but ends up discarding any changed content. Same with the automatic background Sync. However, if I only sync individual files directly, it works as expected.
That said, new files created outside the Nextcloud app still aren’t being recognized.
Again, thank you very much for your help.
I noticed that someone reported the same issue on GitHub:
