Tray icon shows sync fail, hover not problem, but metadata setup error!
  • Nextcloud Server version:
    • Nextcloud 33.0.1
    • #1 SMP PREEMPT Debian 1:6.12.75-1+rpt1~bookworm (2026-03-11)
  • Web server and version:
    • Server version: Apache/2.4.66 (Debian)
  • Reverse proxy and version:
    • nginx version: openresty/1.27.1.2
  • PHP version:
    • PHP 8.4.19 (cli) (built: Mar 16 2026 22:27:46) (NTS)
    • yes
    • recently
    • OMV Container
Summary of the issues you are facing:
Tray icon shows white on red cross but sync was successful
  1. Instelled latest Nextcould Desktop client
  2. was opened and finished sync, Tray icon shows error, Hover of tray icon shows sync completed, settings show metadata error!
{"reqId":"NZmUcogg6Z83E6MLIX2I","level":3,"time":"2026-03-31T19:08:27+00:00","remoteAddr":"83.97.85.45","user":"johannes","app":"PHP","method":"GET","url":"/ocs/v1.php/cloud/capabilities?format=json","scriptName":"/ocs/v1.php","message":"OCA\\Onlyoffice\\FileCreator::create(): Implicitly marking parameter $templateId as nullable is deprecated, the explicit nullable type must be used instead at /var/www/html/custom_apps/onlyoffice/lib/FileCreator.php#145","userAgent":"Mozilla/5.0 (Linux) mirall/33.0.0daily (Nextcloud, org.kde.Platform-6.19.9-200.fc43.x86_64 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"33.0.1.2","clientReqId":"8e540e01-46d3-4225-b6de-e1b7af56eb92","data":{"app":"PHP"}}
{"reqId":"OMQaskSyF0xq3YnuQIzG","level":3,"time":"2026-04-01T05:25:46+00:00","remoteAddr":"83.97.85.45","user":"king_admin","app":"jsresourceloader","method":"GET","url":"/index.php/settings/admin/onlyoffice","scriptName":"/index.php","message":"Could not find resource core/js/dist/systemtags.js to load","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:149.0) Gecko/20100101 Firefox/149.0","version":"33.0.1.2","data":{"app":"jsresourceloader"}}
{"reqId":"y2SVDjgpE9Ir4g6ItjPz","level":3,"time":"2026-04-01T05:43:25+00:00","remoteAddr":"83.97.85.45","user":"johannes","app":"PHP","method":"GET","url":"/ocs/v1.php/cloud/capabilities?format=json","scriptName":"/ocs/v1.php","message":"OCA\\Onlyoffice\\FileCreator::create(): Implicitly marking parameter $templateId as nullable is deprecated, the explicit nullable type must be used instead at /var/www/html/custom_apps/onlyoffice/lib/FileCreator.php#145","userAgent":"Mozilla/5.0 (Linux) mirall/33.0.0daily (Nextcloud, org.kde.Platform-6.19.10-200.fc43.x86_64 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"33.0.1.2","clientReqId":"8d1a443a-758a-4b0d-bb6d-fcd6be240b7c","data":{"app":"PHP"}}
{"reqId":"u7oZ4bGDItcdiJNbrWop","level":3,"time":"2026-04-01T07:44:12+00:00","remoteAddr":"83.97.85.45","user":"king_admin","app":"jsresourceloader","method":"GET","url":"/index.php/settings/admin/onlyoffice","scriptName":"/index.php","message":"Could not find resource core/js/dist/systemtags.js to load","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:149.0) Gecko/20100101 Firefox/149.0","version":"33.0.1.2","data":{"app":"jsresourceloader"}}
  • activity: 6.0.0-dev.0
  • admin_audit: 1.23.0
  • bookmarks: 16.1.3
  • brewmemo: 0.6.0
  • bruteforcesettings: 6.0.0-dev.0
  • calendar: 6.2.1
  • circles: 33.0.0
  • comments: 1.23.0
  • contacts: 8.4.2
  • contactsinteraction: 1.14.1
  • cookbook: 0.11.6
  • dashboard: 7.13.0
  • dav: 1.36.0
  • encryption: 2.21.0
  • end_to_end_encryption: 2.0.0
  • federation: 1.23.0
  • files: 2.5.0
  • files_downloadlimit: 5.1.0-dev.0
  • files_external: 1.25.1
  • files_pdfviewer: 6.0.0-dev.0
  • files_reminders: 1.6.0
  • files_sharing: 1.25.2
  • files_trashbin: 1.23.0
  • files_versions: 1.26.0
  • firstrunwizard: 6.0.0-dev.0
  • fulltextsearch: 33.0.0
  • groupfolders: 21.0.6
  • logreader: 6.0.0
  • notes: 4.13.1
  • notifications: 6.0.0
  • oauth2: 1.21.0
  • onlyoffice: 10.0.0
  • password_policy: 5.0.0-dev.0
  • photos: 6.0.0-dev.0
  • privacy: 5.0.0-dev.0
  • profile: 1.2.0
  • provisioning_api: 1.23.0
  • recommendations: 6.0.0-dev.0
  • related_resources: 4.0.0-dev.0
  • serverinfo: 5.0.0-dev.0
  • settings: 1.16.0
  • sharebymail: 1.23.0
  • support: 5.0.0
  • survey_client: 5.0.0-dev.0
  • suspicious_login: 11.0.0-dev.0
  • systemtags: 1.23.0
  • text: 7.0.0-dev.3
  • theming: 2.8.0
  • twofactor_totp: 15.0.0-dev.0
  • updatenotification: 1.23.0
  • uppush: 2.4.0
  • user_status: 1.13.0
  • viewer: 6.0.0-dev.0
  • weather_status: 1.13.0
  • webhook_listeners: 1.5.0
  • workflowengine: 2.15.0
  • app_api: 33.0.0 (installed 32.0.0)
  • camerarawpreviews: 0.8.8 (installed 0.8.8)
  • keeweb: 0.6.22 (installed 0.6.22)
  • richdocuments: 10.1.2 (installed 10.1.2)
  • testing: 1.23.0
  • user_ldap: 1.24.0 (installed 1.22.0)
