example
longer
example
here
Nextcloud version (eg, 12.0.2): 17.0.3
Operating system and version (eg, Ubuntu 17.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): nginx 1.14
PHP version (eg, 7.1):7.2
Trashbin ist not being emptied e.g. after 8 days.
Setting is: trashbin_retention_obligation’ => ‘7, 8’,
- group folders are used
- a retention policy moves the files to the trashbin. this works great
- Items in trashbin are now 11 days old, but the trashbin policy in the config.php ist set to min age 7 and max age 8
PASTE HERE
PASTE HERE
'passwordsalt' => 'removed',
'secret' => 'removed',
1 => 'servername',
2 => 'some.domain.com',
'datadirectory' => '/opt/data',
'tempdirectory' => '/opt/data/upload-temp',
'dbtype' => 'pgsql',
'version' => '17.0.3.1',
'overwrite.cli.url' => 'https://some.domain.com',
'dbname' => 'somedb',
'dbhost' => 'localhost:5432',
'dbuser' => 'ncdb',
'dbpassword' => 'removed',
'instanceid' => 'removed',
'default_language' => 'de',
'default_locale' => 'de_DE',
'session_lifetime' => 900,
'remember_login_cookie_lifetime' => 0,
'session_keepalive' => false,
'mail_smtpmode' => 'smtp',
'mail_smtpdebug' => true,
'enable_previews' => false,
'trashbin_retention_obligation' => '7, 8',
'loglevel' => 2,
'logdateformat' => 'F d, Y H:i:s',
'logfilemode' => 416,
'log_type' => 'file',
'auth.bruteforce.protection.enabled' => true,
'sharing.minSearchStringLength' => 3,
'upgrade.disable-web' => false,
'mail_from_address' => 'no_reply',
'mail_domain' => 'somedomain.com',
'mail_smtphost' => 'somemailhost.com',
'mail_smtpport' => '25',
'config_is_read_only' => true,
'redis' =>
'host' => '127.0.0.1',
'port' => 6379,
'timeout' => 0.0,
'updater.secret' => 'removed',
The output of your Apache/nginx/system log in `/var/log/____`:
PASTE HERE
