i’m trying to configure trash bin app but I found conflicting info:
here https://docs.nextcloud.com/server/12/user_manual/files/deleted_file_management.html
here they say:
"To ensure that users do not run over their storage quotas, the Deleted Files app allocates a maximum of 50% of their currently available free space to deleted files. If your deleted files exceed this limit, Nextcloud deletes the oldest files"
but here
https://docs.nextcloud.com/server/12/admin_manual/configuration_server/config_sample_php_parameters.html#deleted-items-trash-bin
they do not speak anymore about 50% threshold.
How do these two parts interact?
Thanks in advance
The way I understand this is that there’s always a hardcoded (not configurable) limit where deleted files can never use more than 50% of the quota. At the same time, there’s a time quota which is configurable. So if deleted files exceed either threshold, they are removed.
If you feel like the size quota should be configurable, you should check GitHub.com/nextcloud/server/issues to see if that’s already in the list, and add a new feature request if it’s not.
Thanks very much,
I also think it’s as you say, but my tests seem to say the opposite.
using ‘trashbin_retention_obligation’ => ‘1,2’,
or ‘trashbin_retention_obligation’ => ‘auto’,
For example,I created a user with a quota of 20mb, I loaded a file of 17mb and I deleted it, but it still remains in the trash even if I add and delete other files (the trash also reaches 10 times the presumed maximum size of 10mb).
when I remove ‘trashbin_retention_obligation’ =>…from the config.php file, the 50% threshold seems to work properly.
Have you tried it? Does it work correctly in your instance?
I resolved, I had activated the cron every 15 minutes, then the check on the 50% threshold is done every 15 minutes
Thanks
Actually I have not tried it, but glad to hear it’s working as you expected after cron runs.
I wonder if there is a way to change the 50% threshold though.
maybe this?
Nextcloud seems just to respect the thrash bin quota set on Trashbin.php (DEFAULTMAXSIZE = 50; i.e 50% of my remaining account quota)
Trash bin retention doesn't have effect
I have not already tried it
That’s pretty straightforward. I just set mine to ‘auto, 30’ so we’ll see how that goes after cron runs.
another question, the 50% limit is about 50% of total user quota or 50% of user quota currently unused?
for example, a user who uses 9 of 10 GB has a 5 GB trash bin or a 0,5GB trash bin (50% of free space: 1GB )?
from my tests it seems that it is calculated on the total quota.
Thanks
That’s another good question. The documentation seems to indicate it should be 50% of the free space remaining, although that’s not what your tests are showing. Also I would wonder what happens when you completely fill up your quota (no free space). I would need to test this to see how it works out for me.
Somehow it does not work for me in NC 13.05, file will be deleted, even if I configure to save it.
Info files_trashbin remove "xxx.zzz" (177726B) to meet the limit of trash bin size (50% of available quota)
my config:
'trashbin_retention_obligation' => '7, auto',
'versions_retention_obligation' => '7, auto',
I have file versions saved, but I do not have any files in trash-bin.
It was easy for me to do this! Follow this steps and on my server it works!
- Deactivate APP Deletet Files
- Reboot your Nextcloud
- Activate APP Deletet Files
- Delete one File
- Trashbin was working
