Jâai installaler nextcloud sur un raspberry pi 4 8gb et le tout a bien Ă©tĂ© mais la jâai fait la commande ncdatadir et la depuis ce temps la je ne peux plus rien faire jâai un nextcloud check error. Et aussi je ne comprend pas pourquoi mon systĂšme en mode terminal me rĂ©pond je pense en espagnole. ???
Run
sudo ncp-report
and share output in txt file or via link to a pastebin service
can try
sudo raspi-config
and set the language/locales or run
sudo dpkg-reconfigure locales
and select your language
I can read and understand French, but not write in French, sorry.
@Normandstm apres le transfert, les permissions des rĂ©pertoires parents et du rĂ©pertoire concernĂ© sont elles correctes ? ( RWX pour www-data , je ne suis pas sur de lâutilisateur ).
ces impossible je voir les permissions jâai meme pas access a la commande ls -l dans le terminal
Thank you, I have been able to go back in english and french.
{âreqIdâ:â10TKHkIoUSG1816iWdl1â,âlevelâ:2,âtimeâ:â2021-04-11T19:48:16+00:00â,âremoteAddrâ:"",âuserâ:"â",âappâ:âno app in contextâ,âmethodâ:"",âurlâ:"â",âmessageâ:âTemporary directory /media/mondisquecloud/ncdata/tmp is not present or writableâ,âuserAgentâ:"â",âversionâ:â20.0.2.2â}
{âreqIdâ:â10TKHkIoUSG1816iWdl1â,âlevelâ:3,âtimeâ:â2021-04-11T19:48:17+00:00â,âremoteAddrâ:"",âuserâ:"â",âappâ:âPHPâ,âmethodâ:"",âurlâ:"â",âmessageâ:{âExceptionâ:âErrorâ,âMessageâ:âfopen(/media/mondisquecloud/ncdata/data_dir_writability_test_6073528161e9a.tmp): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/legacy/OC_Util.php#804â,âCodeâ:0,âTraceâ:[{âfunctionâ:âonErrorâ,âclassâ:âOC\Log\ErrorHandlerâ,âtypeâ:"::",âargsâ:[2,âfopen(/media/mondisquecloud/ncdata/data_dir_writability_test_6073528161e9a.tmp): failed to open stream: Permission deniedâ,"/var/www/nextcloud/lib/private/legacy/OC_Util.php",804,{âconfigâ:{âclassâ:âOC\SystemConfigâ},âlâ:{âclassâ:âOC\L10N\LazyL10Nâ},âerrorsâ:[{âerrorâ:âYour data directory is invalidâ,âhintâ:âEnsure there is a file called â.ocdataâ in the root of the data directory.â}],âCONFIG_DATADIRECTORYâ:"/media/mondisquecloud/ncdata",âwebServerRestartâ:false,âsetupâ:{âclassâ:âOC\Setupâ},âurlGeneratorâ:{âclassâ:âOC\URLGeneratorâ},âavailableDatabasesâ:{âmysqlâ:âMySQL/MariaDBâ},âtestFileâ:"/media/mondisquecloud/ncdata/data_dir_writability_test_6073528161e9a.tmp"}]},{âfileâ:"/var/www/nextcloud/lib/private/legacy/OC_Util.php",âlineâ:804,âfunctionâ:âfopenâ,âargsâ:["/media/mondisquecloud/ncdata/data_dir_writability_test_6073528161e9a.tmp",âwâ]},{âfileâ:"/var/www/nextcloud/lib/private/Console/Application.php",âlineâ:161,âfunctionâ:âcheckServerâ,âclassâ:âOC_Utilâ,âtypeâ:"::",âargsâ:[{âclassâ:âOC\SystemConfigâ}]},{âfileâ:"/var/www/nextcloud/console.php",âlineâ:99,âfunctionâ:âloadCommandsâ,âclassâ:âOC\Console\Applicationâ,âtypeâ:"->",âargsâ:[{âclassâ:âSymfony\Component\Console\Input\ArgvInputâ},{âclassâ:âSymfony\Component\Console\Output\ConsoleOutputâ}]},{âfileâ:"/var/www/nextcloud/occ",âlineâ:11,âargsâ:["/var/www/nextcloud/console.php"],âfunctionâ:ârequire_onceâ}],âFileâ:"/var/www/nextcloud/lib/private/Log/ErrorHandler.php",âLineâ:91,âCustomMessageâ:"â"},âuserAgentâ:"â",âversionâ:â20.0.2.2â}
{âreqIdâ:â10TKHkIoUSG1816iWdl1â,âlevelâ:3,âtimeâ:â2021-04-11T19:48:17+00:00â,âremoteAddrâ:"",âuserâ:"â",âappâ:âPHPâ,âmethodâ:"",âurlâ:"â",âmessageâ:âfopen(/media/mondisquecloud/ncdata/nextcloud.log): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/Log/File.php#85â,âuserAgentâ:"â",âversionâ:â20.0.2.2â}
{âreqIdâ:âWe29GrJz4m3CjtpYHigEâ,âlevelâ:2,âtimeâ:â2021-04-11T19:48:21+00:00â,âremoteAddrâ:"",âuserâ:"â",âappâ:âno app in contextâ,âmethodâ:"",âurlâ:"â",âmessageâ:âTemporary directory /media/mondisquecloud/ncdata/tmp is not present or writableâ,âuserAgentâ:"â",âversionâ:â20.0.2.2â}
{âreqIdâ:âWe29GrJz4m3CjtpYHigEâ,âlevelâ:3,âtimeâ:â2021-04-11T19:48:21+00:00â,âremoteAddrâ:"",âuserâ:"â",âappâ:âPHPâ,âmethodâ:"",âurlâ:"â",âmessageâ:{âExceptionâ:âErrorâ,âMessageâ:âfopen(/media/mondisquecloud/ncdata/data_dir_writability_test_60735285ceccb.tmp): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/legacy/OC_Util.php#804â,âCodeâ:0,âTraceâ:[{âfunctionâ:âonErrorâ,âclassâ:âOC\Log\ErrorHandlerâ,âtypeâ:"::",âargsâ:[2,âfopen(/media/mondisquecloud/ncdata/data_dir_writability_test_60735285ceccb.tmp): failed to open stream: Permission deniedâ,"/var/www/nextcloud/lib/private/legacy/OC_Util.php",804,{âconfigâ:{âclassâ:âOC\SystemConfigâ},âlâ:{âclassâ:âOC\L10N\LazyL10Nâ},âerrorsâ:[{âerrorâ:âYour data directory is invalidâ,âhintâ:âEnsure there is a file called â.ocdataâ in the root of the data directory.â}],âCONFIG_DATADIRECTORYâ:"/media/mondisquecloud/ncdata",âwebServerRestartâ:false,âsetupâ:{âclassâ:âOC\Setupâ},âurlGeneratorâ:{âclassâ:âOC\URLGeneratorâ},âavailableDatabasesâ:{âmysqlâ:âMySQL/MariaDBâ},âtestFileâ:"/media/mondisquecloud/ncdata/data_dir_writability_test_60735285ceccb.tmp"}]},{âfileâ:"/var/www/nextcloud/lib/private/legacy/OC_Util.php",âlineâ:804,âfunctionâ:âfopenâ,âargsâ:["/media/mondisquecloud/ncdata/data_dir_writability_test_60735285ceccb.tmp",âwâ]},{âfileâ:"/var/www/nextcloud/lib/private/Console/Application.php",âlineâ:161,âfunctionâ:âcheckServerâ,âclassâ:âOC_Utilâ,âtypeâ:"::",âargsâ:[{âclassâ:âOC\SystemConfigâ}]},{âfileâ:"/var/www/nextcloud/console.php",âlineâ:99,âfunctionâ:âloadCommandsâ,âclassâ:âOC\Console\Applicationâ,âtypeâ:"->",âargsâ:[{âclassâ:âSymfony\Component\Console\Input\ArgvInputâ},{âclassâ:âSymfony\Component\Console\Output\ConsoleOutputâ}]},{âfileâ:"/var/www/nextcloud/occ",âlineâ:11,âargsâ:["/var/www/nextcloud/console.php"],âfunctionâ:ârequire_onceâ}],âFileâ:"/var/www/nextcloud/lib/private/Log/ErrorHandler.php",âLineâ:91,âCustomMessageâ:"â"},âuserAgentâ:"â",âversionâ:â20.0.2.2â}
{âreqIdâ:âWe29GrJz4m3CjtpYHigEâ,âlevelâ:3,âtimeâ:â2021-04-11T19:48:21+00:00â,âremoteAddrâ:"",âuserâ:"â",âappâ:âPHPâ,âmethodâ:"",âurlâ:"â",âmessageâ:âfopen(/media/mondisquecloud/ncdata/nextcloud.log): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/Log/File.php#85â,âuserAgentâ:"â",âversionâ:â20.0.2.2â}
tail: no sâha pogut obrir â/media/mondisquecloud/ncdata/nextcloud.logâ per a llegir: El fitxer o directori no existeix
lorsque je fait http://localhost/nextcloud
jâai lâerreur
Votre rĂ©pertoire nâest pas valide Assurez-vous que le rĂ©pertoire de donnĂ©es contient un fichier â.ocdataâ Ă sa racine. Your data directory is not writable Le problĂšme de permissions peut gĂ©nĂ©ralement ĂȘtre rĂ©solu en donnant au serveur web un accĂšs en Ă©criture au rĂ©pertoire racine. Voir https://docs.nextcloud.com/server/20/go.php?to=admin-dir_permissions.
ha ok merci jâai trouvĂ© quâil me faut me dĂ©placer a la racine en premier et mon ls fonctionne et jâai pu changĂ© les permissions de mon rĂ©pertoire pour 777 et la jâai besoin de savoir ou prenfer mon fichier .ocdata quâil ne parviens pas a trouver
where can I find .ocdata it doesnât find it.
@Normandstm normalment il devrait ĂȘtre dans le repertoire ( Ă la racine) qui contient toutes les donnĂ©es ( ls -la pour le voir) sinon essayĂ© de crĂ©er un fichier .ocdata ( il nây a rien dedans ) et donnez lui les bonnes permissions.
ok super ca ces fait merci. Maintenant il me dit
ou et comment je fait ca.
@Normandstm Quel utilisateur a actuellement les droits sur votre repertoire nextcloud ?
quâen ai t-il pour les rĂ©pertoires parents, www-data a t-il les droit en lecture sur les diffĂ©rent rĂ©pertoire plus haut que celui de vos donnĂ©es ?
pour /media/mondisquecloud/ncdata/, lâutilisateur www-data a t-il toutes les permissions (RWX) ?
la seul place que je peux aller est dans le nextcloudpi panel.
si Jâessaie avec utilisateur http://localhost/nextcloud. je ne viens meme pas a bout de rentrer dedans et les deux utilisateur je crois sont ncp
@Normandstm
jâai oubliĂ© de prĂ©ciser , il faut utiliser le terminal de votre machine avec lâutilisateur root
utilisez la commande ls -l pour voir quâelle utilisateur a les droit sur vos dossier et fichiers
ok si je vais au root / et que je fais ls -l tout est root
@Normandstm maintenant aller dans /media/mondisquecloud/ toujours en tant que root et donnez moi la sortie qui vous est donnée pour ncdata avec ls -l
ne changer aucune permissions pour les dossier et fichier dans /
mysql et root pour un nom du fichier debian-10.3.flag
quâelles sont les permissions ?? ( drwx- ??? )
pi@nextcloudpi:/media/mondisquecloud $ ls -l ncdata
total 155704
-rw-rw---- 1 mysql mysql 16384 avr 11 20:50 aria_log.00000001
-rw-rw---- 1 mysql mysql 52 avr 11 20:50 aria_log_control
-rw-râr-- 1 root root 0 avr 11 06:09 debian-10.3.flag
-rw-rw---- 1 mysql mysql 4319 avr 11 20:50 ib_buffer_pool
-rw-rw---- 1 mysql mysql 79691776 avr 11 21:34 ibdata1
-rw-rw---- 1 mysql mysql 33554432 avr 11 21:34 ib_logfile0
-rw-rw---- 1 mysql mysql 33554432 nov 27 22:55 ib_logfile1
-rw-rw---- 1 mysql mysql 12582912 avr 11 20:51 ibtmp1
-rw-rw---- 1 mysql mysql 0 nov 27 22:55 multi-master.info
drwx------ 1 mysql mysql 2708 avr 11 06:09 mysql
-rw-rw---- 1 mysql mysql 16 avr 11 06:09 mysql_upgrade_info
drwx------ 1 mysql mysql 6564 avr 11 16:45 nextcloud
drwx------ 1 mysql mysql 12 avr 11 06:09 performance_schema
-rw-rw---- 1 mysql mysql 24576 avr 11 20:51 tc.log
@Normandstm Pourriez vous donner le résultat pour le dossier nextcloud ( qui est dans ncdata) en masquant les nom des utilisateur ( et autre données privée).
