Hi there!
I’m using truenas and i’m running nextcloud in a jail of it’s own. Now, in a different jail I have an nginx proxy set up that is working well with radarr/sonarr, but keeps returning ERR_TOO_MANY_REDIRECTS with Nextcloud. Using curl -v https_domain_name shows an error 301 - moved permanentily.
Nextcloud version (eg, 20.0.5): 25.0
Operating system and version (eg, Ubuntu 20.04): TrueNas FreeBSD
Nextcloud config.php:
root@nc:/usr/local/www/nextcloud/config # cat config.php
'apps_paths' =>
0 =>
'path' => '/usr/local/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
1 =>
'path' => '/usr/local/www/nextcloud/apps-pkg',
'url' => '/apps-pkg',
'writable' => false,
'one-click-instance' => true,
'one-click-instance.user-limit' => 100,
'redis' =>
'host' => 'localhost',
'passwordsalt' => 'deleted',
'secret' => 'deleted/',
0 => 'localhost',
1 => 'ip_of_my_truenas_instance',
2 => 'nextcloud.domainname.com',
'datadirectory' => '/usr/local/www/nextcloud/data',
'version' => '25.0.0.18',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'deleted',
'dbhost' => 'deleted',
'dbuser' => 'deleted',
'dbpassword' => 'deleted',
'trusted_proxies' =>
0 => 'ip_of_my_proxy',
Nginx nextcloud config (on nextcloud jail)
root@nc:/usr/local/etc/nginx/conf.d # cat nextcloud.conf
upstream php-handler {
server unix:/var/run/nextcloud-php-fpm.sock;
# Redirect to HTTPS
server {
listen 80 default_server;
listen [::]:80;
location ^~ /.well-known/acme-challenge {
root /usr/local/www/nextcloud/;
try_files $uri $uri/ =404;
location / {
return 301 https://$host:443$request_uri;
server {
listen 443 ssl http2;
server_name _;
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains;"
always;
include conf.d/nextcloud.inc;
Nginx config (on nextcloud jail)
root@nc:/usr/local/etc/nginx # cat nginx.conf
load_module /usr/local/libexec/nginx/ngx_mail_module.so;
load_module /usr/local/libexec/nginx/ngx_stream_module.so;
user www;
worker_processes auto;
pid /var/run/nginx.pid;
events {
use kqueue;
worker_connections 1024;
multi_accept on;
http {
# Basic settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
reset_timedout_connection on;
keepalive_timeout 65;
keepalive_requests 1000;
types_hash_max_size 2048;
server_tokens off;
send_timeout 30;
server_names_hash_max_size 4096;
# Common limits
client_max_body_size 100m; # upload size
client_body_buffer_size 1m;
client_header_timeout 3m;
client_body_timeout 3m;
client_body_temp_path /var/tmp/nginx/client_body_temp;
proxy_connect_timeout 5;
proxy_send_timeout 10;
proxy_read_timeout 10;
proxy_buffer_size 4k;
proxy_buffers 8 16k;
proxy_busy_buffers_size 64k;
proxy_temp_file_write_size 64k;
proxy_temp_path /var/tmp/nginx/proxy_temp;
include mime.types;
default_type application/octet-stream;
# Logs format
log_format main '$remote_addr - $host [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"'
'rt=$request_time ut=$upstream_response_time '
'cs=$upstream_cache_status';
log_format cache '$remote_addr - $host [$time_local] "$request" $status '
'$body_bytes_sent "$http_referer" '
access_log /var/log/nginx/access.log main;
error_log /var/log/nginx/error.log warn;
# GZip config
gzip on;
gzip_static on;
gzip_types text/plain text/css text/javascript text/xml application/x-javascript application/javascript application/xml application/json image/x-icon;
gzip_comp_level 9;
gzip_buffers 16 8k;
gzip_proxied expired no-cache no-store private auth;
gzip_min_length 1000;
gzip_disable "msie6"
gzip_vary on;
# Cache config
proxy_cache_valid 1m;
# Virtual host config
# SSL
ssl_certificate /usr/local/etc/letsencrypt/live/nextcloud.domainname.com/fullchain.pem;
ssl_certificate_key /usr/local/etc/letsencrypt/live/nextcloud.domainname.com/privkey.pem;
# Verify chain of trust of OCSP response using Root CA and Intermediate certs
ssl_trusted_certificate /usr/local/etc/letsencrypt/live/nextcloud.domainname.com/chain.pem;
ssl_session_timeout 1d;
ssl_session_cache shared:MozSSL:10m; # about 40000 sessions
ssl_session_tickets off;
# intermediate configuration
# Keep only TLS 1.2 (+ TLS 1.3)
ssl_protocols TLSv1.2 TLSv1.3;
# Use only strong ciphers
ssl_ciphers TLS-CHACHA20-POLY1305-SHA256:TLS-AES-256-GCM-SHA384:TLS-AES-128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
# Use more secure ECDH Curve
ssl_ecdh_curve X25519:P-521:P-384:P-256;
# Defend against the BEAST attaack
ssl_prefer_server_ciphers off;
#OCSP Stapling
ssl_stapling on;
ssl_stapling_verify on;
include /usr/local/etc/nginx/conf.d/*.conf;
Nginx config (on reverse proxy)
root@reverseproxy:/usr/local/etc/nginx # cat nginx.conf
worker_processes 1;
events {
http {
include mime.types;
sendfile on;
# Redirect all HTTP traffic to HTTPS
server {
listen [::]:80 default_server;
# Import server blocks for all subdomains
include "vdomains/*.conf";
Nginx domain config (on reverse proxy)
root@reverseproxy:/usr/local/etc/nginx # cat vdomains/nextcloud.domainname.com.conf
server {
server_name nextcloud.domainname.com;
access_log /var/log/nginx/cloud.access.log;
error_log /var/log/nginx/cloud.error.log;
include snippets/nextcloud.domainname.com.cert.conf;
include snippets/ssl-params.conf;
location / {
include snippets/proxy-params.conf;
proxy_pass ip_of_my_nextcloud_jail;
location /.well-known/carddav {
location /.well-known/caldav {
Nginx proxy config (on reverse proxy)
koi-utf nginx.conf.save uwsgi_params-dist
koi-win scgi_params vdomains/
mime.types scgi_params-dist win-utf
mime.types-dist sites_enabled/
nginx.conf sites-enabled/
root@reverseproxy:/usr/local/etc/nginx # cat snippets/proxy-params.conf
add_header Front-End-Https on;
add_header Strict-Transport-Security "max-age=2592000; includeSubdomains";
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $server_name;
proxy_set_header X-Forwarded-Ssl on;
proxy_set_header Upgrade %http_upgrade;
proxy_set_header Connection "upgrade";
proxy_http_version 1.1;
To me it appears there is some conflict or some minor missmatch between the reverse-proxy nginx config and the nextcloud jail config, but I’ve been trying to find it for a couple of days now to no avail… Any suggestions are very much appreciated ![]()
