To be clear.... no way to have 2way sync with android client
There doesn’t appear to be a way to have a true 2 way sync (with deletes) for a android client folder.
Is this correct?
I see I can sync a server folder to device (good for downloading from server)
I see I can set a auto upload for a custom folder (good for uploading new files to server)
But if I delete a file on the android it doesn’t delete on server?
So if my thinking is correct the only way to have true file syncing for my file syncing client/server
is to add a android app to do file syncing on top of my file syncing software.
Got it, I think
Anyone know a good android file syncing app?
FolderSync?
Syncthing?
As someone who knows a little background but none of the code involved, here are two reasons I can think of for why the Android app would work the way it does:
  1. UX choice - most people delete things from their phones because they don’t want them taking up space, but they’re less likely to have that problem on any cloud.
    These files were important enough to have been uploaded (auto- or not) or manually selected for download/sync, so they shouldn’t be removed from the server unless the user makes a deliberate choice (via the app itself) to do so. “Just” sync apps like the ones you mentioned have different user expectations.
  2. Technical limitations - Android doesn’t give apps their own general-purpose folders to ‘own’; it either gives them free access to storage or it doesn’t. For this reason, it also isn’t good at notifying apps to changes in “their” folders. It can inform apps that new media is available within the volume and let them make their own decisions about it, but that’s only for certain file types.
    Any app that wants to “own” and sync a folder will have to add its own scheduled background task to poll for changes. Several choices will need to be presented to the user, so that battery life/delay trade-offs are what the user intends. To my knowledge this extensive job hasn’t been done on the Nextcloud Android app, and I don’t see a ticket for it at first search, but I’d love to see it added.
For what you want, I can recommend:
  1. If you want to remove something from your Nextcloud, use the Nextcloud app to delete it, and you’ll be prompted to remove it on the server. Just use the app as your file manager for this purpose, if there’s nothing complicating your use-case.
  2. If you’re going to use a different sync app to delete things on the server end automatically, I’ve had luck with SyncThing. It would be best if the SyncThing server directory was not within your Nextcloud directory, as Nextcloud’s database believes itself to be the authority on everything that’s there.
    If the same server is running Nextcloud and SyncThing, and you want files synced using SyncThing to show up in Nextcloud, see Configuring External Storages and pick Local. If they’re on separate servers, choose your connection protocol. Either way, don’t forget to configure the cron job so that Nextcloud sees any changes you make via SyncThing.
The best to you,
mactrent
For now
Synchronize Ultimate
[https://play.google.com/store/apps/details?id=com.icecoldapps.synchronizeultimate&hl=en_US&showAllReviews=true]
Does everything I want it to do.
1 way sync, 2 way sync, with or without deletion, timestamp folder creation,
Rules, conditions, file sync using regex patterns on files and folders, schedules and
the list goes on.
Yes, you are right, some things I want 1 way like camera pics, upload and
“delete source file”.
Somethings I want 2 way sync with deletion.
I have app that makes nightly bu’s on android and only retains 3 most recent copies
and deletes older copies. With auto upload server would end up saving all copies with
no delete and don’t want to have to keep manually deleting old copies.
Or when syncing a folder should scan entire folder and sync all files not just new files
and skip old files.
Guess I expected more features from a modern android cloud client.
I’m not knocking NC, love it.
So, I’m a bit late to the party, but i haven’t messed with Nextcloud since I asked a similar question and was told basically “yeah, it should do that” (Mobile App Functionality: Sync Folders) and judging from your post here that is apparently not the case (which makes me sad, as I was really hoping to migrate away from Dropbox).
Having said that, I’ve used an app on Android for years called DropSync (by Metactrl, who also make similar apps for Box, Google Drive, OneDrive, something called MEGA, etc). For free it will completely synchronize (two-way) a folder on your Android device with a folder in Dropbox, which is something the native Dropbox app does not do, and my understanding is that no app is allowed to do on iOS unless Apple were to relax restrictions in their API. There isn’t a folder ‘ownership’ that I’m aware of, or maybe it just sortof pretends it ‘owns’ all the folders you configure. The Pro version does the same, but for multiple files, and is well worth the price. I sent an email to Metactrl to see if they might consider making a version for NextCloud, because that would be amazing. But in the meantime, I’m trying out Synchronize Ultimate
In my case, I synchronize the downloads, DCIM and documents folders both between my and my wife’s phones and with a Windows server VM. I wrote a program (running as a Windows service) that renames my pictures and video by timestamp and sorts them into folders by date, and Dropsync takes care of propagating all the changes to all the phones. Anything over two weeks old gets moved to backed-up storage media which is scanned by Plex so we can stream it all to TVs or devices without taking up space. Consequently the files are moved off of our phones at that time. For this to work it’s gotta be full two-way sync in all places, so that’s the one thing holding me up from switching to NextCloud.
Synchronize Últimate is the only one that works. It does work though.
FolderSync work well for me.
FolderSync does the job, that’s right.
But Folder Sync does not read the catalogue-files from Owncloud and Nextcloud.
So, the FolderSync App always parses the whole directory-structure to find changes.
I am using Folder Sync Pro.
I have a structure like this (SD-Card NOT formated as internal storage):
documents
  • Audio
  • Pictures
  • Documents
Content: About 9.000 files with about 70GB data.
I upload a new picture to the server and at least 1 or 2 hours later (after 1/4 of my battery consumption is gone) Folder Sync fails due to the amount of data.
So, forget Folder Sync.
Till last week I used Owncloud since 6 years.
But I got annoyed about the missing feature of 2-way-folder-sync like on the desktop-app.
Then a colleague told me he uses nextcloud and they have the feature.
And indeed, there was written (Mobile Sync App):
Blockquote
The apps allow you to access, sync and upload your data and feature instant upload for fotos and videos, upload management and more features.
Blockquote
But you have to create a home-folder where you can download server-folders
no possibility of specific folder-pairs like on the desktop-clients. No difference to Owncloud.
I think there will never be such an important possibility like folder-pair-based 2-way-sync with the native nextcloud or owncloud-client.
I wonder what may be the problem to say: Hey, Nexcloud app, here is my local folder “storage/3452-335/dcim”, please sync it the the server-folder “smartphone1/dcim”.
Perhaps some developer can explain that, please?
By the way
After one week of migrating from Owncloud to Nextcloud I came to the conclusion that is was not worth the effort :pensive:
Greetings
Patrick
Hello Friends :slight_smile:
I am new to Nextcloud, trying out https://ecloud.global/ from https://e.foundation/ with a Windows desktop PC and Android handy.
I have used Dropbox with Dropsync (mentioned by @CinciTech ) for such a two-way-synchronization.
Question: is there in the meantime a solution/app/
 for this task?
THANKS!
imthenextandonly
That’s exactly (!) the same reason, the same setting, why I was led to this thread
Since a feew weeks I also use /e/OS and have used Dropbox & Dropsync Pro with several folder pairs, e.g. DCIM or Whatsapp subfolders – organizing my files esp. under Windows (Desktop PC) and not with the too small smartphone and its one-finger-interface
Hi Fans of syncing via NC!
Two questions in advance: concerning the current and new NC Android client: Isn’t that 2way sync able? Unfortunately I couldn’t find an online documantation of what it’s able and what not. Do I have to press “sync” in each folder’s context menu again and again when I want my SD Cards data to be uptodate?
I am very happy with NC since several years by now. With its Web and desktop client access. Until last week I was using its Android App only to occasionally download a file onto my Galaxy Smartphone. As all Instant Upload features were not working properly on Samsung Galaxies I Used FolderSync Pro the past years to do that job. So it was very interesting to read what @predatorbgodfather wrote last August 19th. Patrick, have you found another app that reads the OC/NC catalogue files? What about the further above mentioned “Synchronize Últimate” ?!
Since FolderSync Pros new Version 3.X is all of the sudden not working anymore with (my) old NC Accounts and I wasn’t able to set one of my three NC connections during more than one hour that is another reason not to continue working with FolderSync Pro.
Since about three days I am downloading the 400 GB of data of my three NC-Installations in my home wifi. I am at 46 GB so far. With my Galaxy S9+ it does download at least. Let’s see whether it will work out or not.
Happy for any comment! @webaschtl, @tobiasKaminsky
Search for AutoSync by MetaCtrl – this is a good sync app with Nextcloud integration.
Thanks! But my web technicion told me to forget the idea to back up 360 GB of Clouddata on my Android - only because the micro sd has that much space left. They (Smrat phone and sd card) wouldn’t be made to perform as backup ));;;
I had been using DropSync from MetaCtrl in my “former life with Google” :wink: It worked/works nearly without problems.
But without the Play Store it’s not possible to get the full/pay version of DropSync. That’s the (only) disadvantage of the tools from MetaCtrl
It’s definitely the best so far.
It’s peer to peer
 and that makes it even more powerful.
Yet you can install it on a server and use it in a centralized manner.
Anything new? I’ve tried Ultimate Sync but I haven’t found a way to automatically sync. It would be great if there was an open source app for this or better
 if Nextcloud Client would provide a real local sync folder for Android. I’ve seen Synchting, not sure what I’m suppose to do with this.
