I’m really enjoying Nextcloud; thanks to the developers and supporters!
| NextCloudPi version | v1.50.1 |
| NextCloudPi image | NextCloudPi_08-16-22 |
| OS | Debian GNU/Linux 11. 5.10.92-v8+ (aarch64) |
| automount | yes |
| USB devices | sda |
| datadir | /media/NextCloudDrive/ncdata/data |
| data in SD | no |
| data filesystem | btrfs |
| data disk usage | 2.6G/3.7T |
| rootfs usage | 2.6G/29G |
| swapfile | /var/swap |
| dbdir | /media/NextCloudDrive/ncdatabase |
| Nextcloud check | ok |
| Nextcloud version | 24.0.3.2 |
| HTTPD service | up |
| PHP service | up |
| MariaDB service | up |
| Redis service | up |
| HPB service | up |
| Postfix service | up |
| Internet check | ok |
| public IPv4 | redacted |
| public IPv6 | not found |
| Port check 80 | closed |
| Port check 443 | closed |
| IP | redacted |
| gateway | redacted |
| Interface | eth0 |
| certificates | none |
| NAT loopback | no |
| Uptime | 1:24 |
Nextcloud version (eg, 20.0.5): 24.0.3.2
Operating system and version (eg, Ubuntu 20.04): Debian GNU/Linux 11. 5.10.92-v8+ (aarch64)
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.54 (Debian)
PHP version (eg, 7.4): pi@nextcloudpi:~ $ php --version PHP 7.4.30 (cli) (built: Jul 7 2022 15:51:43) ( NTS ) Copyright (c) The PHP Group Zend Engine v3.4.0, Copyright (c) Zend Technologies with Zend OPcache v7.4.30, Copyright (c), by Zend Technologies
Times in the Tasks modules are incorrect.
- Create card in Deck, set date and time to e.g.
2022-10-03 11:30 - Open Tasks, time is 4 hours later (i.e. GMT, rather than EDT), e.g.
2022-10-03 15:30
tail of /var/log/apache2/error.log (current time 13:17):
[Sun Oct 02 12:53:59.734754 2022] [authz_host:error] [pid 963:tid 547893137792] [client redacted:50774] AH01753: access check of 'localhost' to /img/favicon.png failed, reason: unable to get the remote host name
[Sun Oct 02 12:54:31.718250 2022] [authz_host:error] [pid 963:tid 547893137792] [client redacted:50774] AH01753: access check of 'localhost' to /img/favicon.png failed, reason: unable to get the remote host name
[Sun Oct 02 13:04:05.415269 2022] [authz_host:error] [pid 963:tid 547951886720] [client redacted:50774] AH01753: access check of 'localhost' to /img/favicon.png failed, reason: unable to get the remote host name
[Sun Oct 02 13:07:46.366780 2022] [authz_host:error] [pid 964:tid 547851174272] [client redacted:39802] AH01753: access check of 'localhost' to /img/favicon.png failed, reason: unable to get the remote host name
tail of /var/log/apache2/nc-error.log (current time 13:16):
[Sun Oct 02 11:26:14.724711 2022] [proxy_fcgi:error] [pid 963:tid 547524432256] [client 10.0.0.13:51058] AH01071: Got error 'PHP message: PHP Fatal error: Uncaught Doctrine\\DBAL\\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/nextcloud/lib/private/DB/Connection.php:139\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1519): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1041): Doctrine\\DBAL\\Connection->getWrappedConnection()\n#2 /var/www/nextcloud/lib/private/DB/Connection.php(261): Doctrine\\DBAL\\Connection->executeQuery()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\\DB\\Connection->executeQuery()\n#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(281): Doctrine\\DBAL\\Query\\QueryBuilder->execute()\n#5 /var/www/nextcloud/lib/private/AppConfig.php(411): OC\\DB\\QueryBuilder\\QueryBuilder->execute()\n#6 /var/www/nextcloud/lib/private/AppConfig.php(176): OC\\AppConfig->loadConfigValues()\n#7 /var/www/nextcloud/lib/p...'
[Sun Oct 02 11:26:14.726025 2022] [proxy_fcgi:error] [pid 964:tid 547516039552] [client redacted:51060] AH01071: Got error 'PHP message: PHP Fatal error: Uncaught Doctrine\\DBAL\\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/nextcloud/lib/private/DB/Connection.php:139\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1519): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1041): Doctrine\\DBAL\\Connection->getWrappedConnection()\n#2 /var/www/nextcloud/lib/private/DB/Connection.php(261): Doctrine\\DBAL\\Connection->executeQuery()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\\DB\\Connection->executeQuery()\n#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(281): Doctrine\\DBAL\\Query\\QueryBuilder->execute()\n#5 /var/www/nextcloud/lib/private/AppConfig.php(411): OC\\DB\\QueryBuilder\\QueryBuilder->execute()\n#6 /var/www/nextcloud/lib/private/AppConfig.php(176): OC\\AppConfig->loadConfigValues()\n#7 /var/www/nextcloud/lib/p...'
[Sun Oct 02 11:26:19.732440 2022] [proxy_fcgi:error] [pid 964:tid 547499254144] [client redacted:51070] AH01071: Got error 'PHP message: PHP Fatal error: Uncaught Doctrine\\DBAL\\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/nextcloud/lib/private/DB/Connection.php:139\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1519): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1041): Doctrine\\DBAL\\Connection->getWrappedConnection()\n#2 /var/www/nextcloud/lib/private/DB/Connection.php(261): Doctrine\\DBAL\\Connection->executeQuery()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\\DB\\Connection->executeQuery()\n#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(281): Doctrine\\DBAL\\Query\\QueryBuilder->execute()\n#5 /var/www/nextcloud/lib/private/AppConfig.php(411): OC\\DB\\QueryBuilder\\QueryBuilder->execute()\n#6 /var/www/nextcloud/lib/private/AppConfig.php(176): OC\\AppConfig->loadConfigValues()\n#7 /var/www/nextcloud/lib/p...'
https://gist.github.com/JohnAtl/0d18416b0845937b864621b0e3859a56
Shown here are Tasks on the left, and the Calendar on the right (which is correct, as is the Deck).
