Nextcloud version (eg, 20.0.5): 24.0.4
Operating system and version (eg, Ubuntu 20.04): 22.04.1
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.52
PHP version (eg, 7.4): 8.1
I have an access problem. Our nextcloud server (self hosted) is in Germany.
From some countries the access results in a timeout.
I have tested via VPN. Czech Republic, Hong-Kong, Sweden and USA worked.
Israel and the Philippines do not work.
I think your hosting provider e.g. Hetzner, Strato, ā¦
But maybe the access from Israel and Philippines works, too.
Maybe it is a problem with your VPN provider.
It is very unlikely that there is a routing problem between e.g. Israel and your server. Then more likely between the ASN of the Israel provider and the ASN of your provider. That again seems quite unlikely to me. Thousands or millions of systems would have to be affected.
Thanks. The last hop is form all sources the same. After that the traceroute does not help (i think Telekom blocks traceroute). Sorry. But it seems to be a problem at Telekom or in the web application / server firewall.
Itās the ISP! Tried to access our company website (not the cloud!) and got a timeout as well.
Now Iām waiting for feedback from Israel if our partner having the same troubles.
Strange. My contact in Israel confirmed that they can access our company website.
And now I can access the website too via Israel-VPN but our cloud is still not accessible.
Got another traceroute to our cloud and our website attached.
are both Nextcloud and the company website hosted on the same ip range? If not, this doesnāt say much. Also, your contact in Israel would most likely access your Nextcloud from a different IP range than you would over the VPN.
Are you using something like CrowdSec on your server or anything else in front of your server that does some magic filtering or geo-blocking? If not, the problem is most likely not on your end.
And on that firewall appliance no load balancing, proxying, filtering etc is beeing doneā¦?
Nope, you can only see the IP address that initiated the connection, which would be the address your VPN provider assigned to you in Israel, respectively the IP address of the internet connection of your contact there. If there are no deny entries, you could also look at the logs of the web server. If you donāt see anything there either, I would ask the ISPā¦
