Thunderbird sync to nextcloud calandar problem
hi i have a problem, i have add nextcloud calandar to my thunderbird over old way with link directly. i can show entries and can add entries.
but, if i delete in online calendar in thunderbird a entry, in thunderbird it was deletet but in nextcloud entrie was not delete, why? what is problem here, why not complete 2 way sync?
2nd problem is,m if i delete a calendar entry in thunderbird, remider was refresh and come on foreground of pc, normal it comes only in fireground if a date was in remind status…
hope yoou have ideas, regards
Do you use an extension in Thunderbird like TbSync or similar?
When you delete an event, you probably should see some activity in the webserver logs. If there is nothing, the app does not do a delete, if there is an entry, there might be an error …
