Nextcloud 32 RC3 is now available on our download server! ![]()
We’d love your help putting this release through its paces.
If you run into any issues, please report them in the appropriate GitHub repository. ![]()
Next RCs are planned on next Thursdays. Stay tuned!
Downloads
Changelog
server
- Feat(encryption): Add integration tests for occ commands and fix them (server#55060)
- Fix(PWA): fix standalone window margins (server#55064)
- Fix(unified-search): make sure date range option is translated (server#55076)
- Fix(ownCloud): ensure that `accounts.display_name` fits into `users.displayname` (server#55078)
- Fix(files_sharing): use `newPassword` always for the unsaved password (server#55082)
- Fix(settings): rename “Settings presets” to “Quick presets” (server#55084)
- Fix(contactsmenu): adjust padding to new design (server#55088)
- Fix: Dispatch favorite event with an actual path (server#55127)
- Fix: handleIMip undefined array key (server#55138)
- Build: Update 3rdparty ignorelist (server#55145)
- Fix: always use english name for recently contacted category (server#55146)
- Fix(Updater): Lower deadlock log level from warning to info (server#55150)
- Fix: Allow hyphen in appid (server#55152)
- Fix: make sure default contact exists by default (server#55154)
- Fix(userconfig): set ‘mail’ as indexed (server#55159)
- Fix(TaskProcessing): Cache task types by user language (server#55165)
- Fix(lexicon): trigger email indexing (server#55167)
3rdparty
app_api
firstrunwizard
- Fix: ensure modal always has a min height to prevent jumping (firstrunwizard#1691)
- Fix: always use the internal back button (firstrunwizard#1692)
logreader
notifications
photos
survey_client
- Chore(CI): Adjust testing matrix for Nextcloud 32 on stable32 (survey_client#375)
- Admin ui: fix checkbox toggles not working (survey_client#379)
text
- Fix(createEditor): always provide editor. (text#7646)
- Fix(readonly-bar): Clean up read-only menu bar to behave consistently with normal menu bar (text#7651)
