Theming - Slogan encoding issue
example
longer
example
here
Nextcloud version (eg, 12.0.2): 15.0.4
Operating system and version (eg, Ubuntu 17.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): Apache2 2.4.29
PHP version (eg, 7.1): PHP 7.2.15-0ubuntu0.18.04.1
Browser: Chrome on Windows Version 72.0.3626.109 (Official Build) (64-bit)
Entering an apostrophe character in the “slogan” theming dialog renders a character code in the About box instead of the character.
  1. Enter an apostrophe in the slogan box : “Myco’s filing cabinet”
  2. Open the About box
If you want any of the further config/logs, let me know.
MariaDB [nextcloud]> select * from oc_appconfig where appid="theming" AND configkey="slogan";
| appid   | configkey | configvalue            |
| theming | slogan    | Newco's filing cabinet |
1 row in set (0.00 sec)
The slogan is stored in the database table oc_appconfig, appid = “theming”, configkey = “slogan”.
You should have a look how it is stored there.
It looks OK in there. I guess the issue is on the rendering side. It’s also messed up when I go back to the Settings page to edit. Maybe the read from the database isn’t handling it nicely.
Try to escape the ’ => \’ in the database table.
I can confirm this issue when using double-quotes in the slogan.
They are shown as " on the about dialog, but on the login page everything is fine.
Nextcloud Version: 15.0.4
PHP: 7.2.14
MySQL: 5.7.23
Using a single \ makes no difference. in the database
Using triple \ gives me a slash on the displayed output in addition to the 'and a single slash in the database.
MariaDB [nextcloud]> update oc_appconfig SET configvalue="Newco\'s filing cabinet" where oc_appconfig.appid="theming" AND oc_appconfig.configkey="slogan";
Query OK, 0 rows affected (0.01 sec)
Rows matched: 1  Changed: 0  Warnings: 0
MariaDB [nextcloud]> update oc_appconfig SET configvalue="Newco\\\'s filing cabinet" where oc_appconfig.appid="theming" AND oc_appconfig.configkey="slogan";
Query OK, 1 row affected (0.00 sec)
Rows matched: 1  Changed: 1  Warnings: 0
| theming | slogan    | Newco\'s filing cabinet |
You may try a double backslash too but I fear it’s a problem with the Nextcloud-code, which handles such cases seemingly incorrectly.
That’s my guess too, I will create an issue when I’m back at my PC.
There already was an issue about this misbehaviour:
