Teams (circles) not working after instance URL was changed
    • 32.0.3
    • Ubuntu 24.04.3
    • Apache 2.4.58
    • PHP 8.3.6
    • yes
    • we were preparing this new NextCloud system, created Teams (circles), tested them and all was working, until we changed the url from https://system1.domain.ca to https://system2.domain.ca
    • System is installed on a VM
    • no
We had an old owncloud instance named https://system1.domain.ca. We installed a new Nextcloud instance (the one with the problem) with version 32.0.3, the Nextcloud instance was originally referred to as https://system2.domain.ca. We created Teams (circles) and added members. Everything was working fine until our migration. We decommissioned the old Owncloud instance and changed the url for the Nextcloud instance from https://system2.domain.ca to https://system1.domain.ca
After this change the Teams show with the number of original members, but if we click on the Teams, the members are not shown. Also the members are not able to reach their shared resources. The teams got broken during the change. I went into the oc_circles* tables and see that an “Instance” field is referred here, I think that is what broke our Teams, how can I change the instance on the Teams app from https://system2.domain.ca to https://system1.domain.ca to get my Teams to work again?
  1. Log into the Nextcloud instance and open any Team, the number next to the team will show the available members but the members don’t appear.
Opening the Team doesn't trigger an error in the log file.
PASTE
PASTE HERE
        "cors.allowed-domains": [
        "htaccess.RewriteBase": "\/",
        "dbtype": "mysql",
        "activity_expire_days": 200,
        "version": "32.0.3.2",
        "default_phone_region": "CA",
        "logtimezone": "UTC",
        "loglevel": 2,
        "ldapIgnoreNamingRules": false,
        "files_external_allow_create_new_local": "true",
        "filelocking.enabled": true,
        "redis": {
            "port": 6379,
            "timeout": 1.5,
            "dbindex": 0,
            "persistent": false
        "appstore.experimental.enabled": true,
        "enable_previews": "false",
        "preview_libreoffice_path": "\/usr\/bin\/libreoffice",
        "quota_include_external_storage": false,
        "appcodechecker": false,
        "versions_retention_obligation": "auto, 5",
        "trashbin_retention_obligation": "1,1",
        "enabledPreviewProviders": [
            "OC\\Preview\\PNG",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\GIF",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\DCM",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\Illustrator",
            "OC\\Preview\\Postscript",
            "OC\\Preview\\Photoshop",
            "OC\\Preview\\TIFF"
        "mail_smtpmode": "smtp",
        "mail_smtpauth": true,
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpport": "465",
        "mail_smtpsecure": "ssl",
        "integrity.excluded.files": [
            "core\/css\/header.css",
            "core\/img\/favicon.ico",
            "core\/img\/background.jpg",
            "core\/img\/logo.svg",
            "core\/img\/logo-icon.svg",
            "core\/img\/favicon.svg",
            "updater\/vendor\/autoload.php",
            "updater\/vendor\/composer\/autoload_real.php",
            "updater\/vendor\/composer\/autoload_static.php"
        "debug": false,
        "singleuser": false,
        "has_rebuilt_cache": true,
        "files_antivirus.av_path": "\/usr\/bin\/clamscan",
        "allow_user_to_change_mail_address": "",
        "encryption.legacy_format_support": false,
        "encryption.key_storage_migrated": false,
        "app_install_overwrite": [
            "impersonate"
        "mysql.utf8mb4": true,
        "mail_sendmailmode": "smtp",
        "updater.release.channel": "stable"
  • circles: 32.0.0
  • contacts: 8.1.1
  • contactsinteraction: 1.13.1
  • dav: 1.34.2
  • federation: 1.22.0
  • files: 2.4.0
  • files_external: 1.24.0
  • files_reminders: 1.5.0
  • files_sharing: 1.24.1
  • files_trashbin: 1.22.0
  • files_versions: 1.25.0
  • guests: 4.6.0
  • impersonate: 3.0.0
  • notifications: 5.0.0-dev.0
  • oauth2: 1.20.0
  • privacy: 4.0.0-dev.0
  • profile: 1.1.0
  • provisioning_api: 1.22.0
  • serverinfo: 4.0.0-dev.0
  • settings: 1.15.1
  • sharebymail: 1.22.0
  • support: 4.0.0-dev.0
  • survey_client: 4.0.0-dev.0
  • systemtags: 1.22.0
  • text: 6.0.1
  • theming: 2.7.0
  • updatenotification: 1.22.0
  • user_ldap: 1.23.0
  • user_status: 1.12.0
  • viewer: 5.0.0-dev.0
  • weather_status: 1.12.0
  • webhook_listeners: 1.3.0
  • workflowengine: 2.14.0
  • activity: 5.0.0-dev.0 (installed 4.0.0)
  • admin_audit: 1.22.0 (installed 2.1.3)
  • app_api: 32.0.0 (installed 32.0.0)
  • carnet: 0.25.6 (installed 0.25.6)
  • checksum: 1.2.6 (installed 1.2.6)
  • circlesdb: 1.8.2 (installed 1.8.2)
  • cms_pico: 1.0.21 (installed 1.0.21)
  • comments: 1.22.0 (installed 1.21.0)
  • dashboard: 7.12.0 (installed 2.0)
  • encryption: 2.20.0 (installed 1.3.0)
  • files_rightclick: 0.15.1 (installed 1.6.0)
  • files_texteditor: 2.15.1 (installed 2.15.1)
  • firstrunwizard: 5.0.0-dev.0 (installed 1.1)
  • fulltextsearch_elasticsearch: 31.0.0 (installed 31.0.0)
  • logreader: 5.0.0-dev.0 (installed 0)
  • photos: 5.0.0-dev.1 (installed 4.0.0-dev.1)
  • recommendations: 5.0.0-dev.0 (installed 4.0.0)
  • theming_customcss: 1.18.0 (installed 1.18.0)
  • twofactor_totp: 14.0.0
  • user_external: 3.4.0 (installed 3.4.0)
Using occ circles:check might be helpful in this scenario.
Thank you, I get the following:
sudo -u www-data php nextcloud/occ circles:check
Checking loopback address.
. The loopback setting is mandatory and can be checked locally.
. The address you need to define here must be a reachable url of your Nextcloud from the hosting server itself.
. By default, the App will use the entry ‘overwrite.cli.url’ from ‘config/config.php’.
  • testing current address: https://https://box.bic.mni.mcgill.ca
  • You do not have a valid loopback address setup right now.
Please write down a new loopback address to test: box.bic.mni.mcgill.ca
format must be http[s]://domain.name[:post][/path]
Please write down a new loopback address to test: https://system1.domain.ca
I am having exactly the same issue reported here:
This is confirmed to be a bug when upgrading from NC 32.0.2 to NC 32.0.3 (with Teams 32.0.0). I reverted to NC 32.0.2 from our backups and the issue is gone.
May I point you on the double-“https://”? - Either it is an input error while typing the posting or it really is a configuration error.
