Previous versions of Nextcloud had an awesome taskbar icon (it was the actual Nextcloud logo). The current version (2.3.3) is a generic, checkmark inside a green circle. Not only is it not representative of Nextcloud, but it is easily confused with other similar icons…same color, same shape, same look.
Can you identify Nextcloud’s icon at a glance?
Would it be possible to restore the original icon?
Thanks in advance and thanks for the great software!
–Daniel!
