30.0.2
Archlinux
Apache 2.4.62
Linuxserver.io SWAG
- PHP version (e.g, 8.3):
PHP Legacy 8.2.26
Yes
When I wanted to backup my database before upgrading like I always do.
- Installation method (e.g. AIO, NCP, Bare Metal/Archive, etc.)
Archive
- Are you using Cloudflare, mod_security, or similar? (Yes / No)
No
As always I tried to backup my database before upgrade using:
mariadb-dump -u root nextcloud >.backup.sql
And the output:
mariadb-dump: Got error: 1030: "Got error 194 "Tablespace is missing for a table" from storage engine InnoDB" when using LOCK TABLES
Then I tried this:
mariadb-check -A --auto-repair -u root
And at the end of output:
Repairing tables
nextcloud.oc_webauthn
Warning : Tablespace is missing for table 'nextcloud/oc_webauthn'
Error : Got error 194 "Tablespace is missing for a table" from storage engine InnoDB
error : Corrupt
I never had the “Two-Factor WebAuthn” app!
Provided in Summery section.
Nextcloud.
100 line tail:
occ config:list system:
occ app:list:
Thanks ^^
