example
longer
example
here
Nextcloud version (eg, 18.0.2): 17.0.5
Operating system and version (eg, Ubuntu 20.04): FreeNAS-11.3-U2
Apache or nginx version (eg, Apache 2.4.25): nginx-1.16.1
PHP version (eg, 7.1): PHP 7.1.33
The system info page failed with 504 timed out error
- Login Nextcloud web interface with an admin account
- Click on the user icon on the upper left corner
- Click on Settings from the pull down menu
- Click on System on the left pane
Error PHP A non-numeric value encountered at /usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#52 2020-04-21T18:04:10+0100
'instanceid' => '***REMOVED-FOR-SECURITY***',
'passwordsalt' => '***REMOVED-FOR-SECURITY***',
'secret' => '***REMOVED-FOR-SECURITY***',
0 => '***REMOVED-FOR-SECURITY***',
1 => '***REMOVED-FOR-SECURITY***',
2 => '***REMOVED-FOR-SECURITY***',
3 => '***REMOVED-FOR-SECURITY***',
4 => '***REMOVED-FOR-SECURITY***',
'datadirectory' => '/usr/local/www/nextcloud/data',
'version' => '17.0.5.0',
'overwrite.cli.url' => '***REMOVED-FOR-SECURITY***',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbport' => '3306',
'dbuser' => '***REMOVED-FOR-SECURITY***',
'dbpassword' => '***REMOVED-FOR-SECURITY***',
'apps_paths' =>
0 =>
'path' => '/usr/local/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
1 =>
'path' => '/usr/local/www/nextcloud/apps-pkg',
'url' => '/apps-pkg',
'writable' => false,
'theme' => '',
'loglevel' => 2,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => '***REMOVED-FOR-SECURITY***',
'mail_domain' => '***REMOVED-FOR-SECURITY***',
'mail_smtpauth' => 1,
'mail_smtphost' => '***REMOVED-FOR-SECURITY***',
'mail_smtpport' => '***REMOVED-FOR-SECURITY***',
'mail_smtpname' => '***REMOVED-FOR-SECURITY***',
'mail_smtppassword' => '***REMOVED-FOR-SECURITY***',
'memcache.local' => '\OC\Memcache\APCu',
–access.log–
***REMOVED-FOR-SECURITY*** - ***REMOVED-FOR-SECURITY*** [21/Apr/2020:18:05:10 +0100] "GET /settings/admin/serverinfo HTTP/2.0" 504 562 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_4) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36" "-"rt=60.000 ut=60.001 cs=-
–error.log–
2020/04/21 18:05:10 [error] 19429#101714: *1676 upstream timed out (60: Operation timed out) while reading response header from upstream, client: ***REMOVED-FOR-SECURITY***, server: ***REMOVED-FOR-SECURITY***, request: "GET /settings/admin/serverinfo HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "***REMOVED-FOR-SECURITY***"
