System Address Book not re-initialized after re-enabling (AIO)
Environment:
  • Nextcloud AIO 12.3.0
  • Nextcloud 32.0.3
  • Ubuntu Server 24.04.3 LTS
Description of the issue:
I disabled the following option in Groupware settings:
Groupware → System Address Book → Disable
After a few days, I enabled this option again.
Since re-enabling it, the System Address Book is not initialized again:
  • The System Address Book does not appear to be recreated
  • Contacts from the System Address Book are not visible in the Contacts app
  • This affects the admin user as well
No further configuration changes were made between disabling and re-enabling the feature.
Expected behavior:
After enabling System Address Book, it should be automatically re-initialized and its contacts should become visible again in the Contacts app.
