Syncthing have a owner problem
when i use syncthing. I touch a file in node1 owner is www.but sync to node2 owner is root…how can i config.thank you.
whats the connection to nextcloud here?
it could be a syncthing problem…
i use syncthing make nextcloud HA. it can sync apps.themes.config.
see what someone wrote underneath some of your other postings with the same content:
in general it would be better if you’d keep to the nc-guidelines and the nc code of conduct which tell you that you should keep to the subject of the thread you’re answering AND to avoid crosspostings.
