Hi. I have the nextcloud client installed on Mac osx with Mojave. When I want to sync large files from the server to the Mac, it prevents me from closing the connection to the file.
Can anyone tell me how to fix that?
What is large? Please name a size.
The screenshot contains spanish and I am unable to understand.
Unfortunately you did not include the log as text so using translation tools is failing.
What do you mean exactly?
5GB
Sorry.
This.
| [OCC::WebFlowCredentials::slotFinished | request finished |
| [OCC::AbstractNetworkJob::slotFinished | QNetworkReply::RemoteHostClosedError “Conexión cerrada” QVariant(int, 207) |
| [OCC::WebFlowCredentials::stillValid | QNetworkReply::RemoteHostClosedError |
| [OCC::WebFlowCredentials::stillValid | “Conexión cerrada” |
| [OCC::LsColJob::finished | LSCOL of QUrl(“https://nextcloud/remote.php/dav/files/luismi/Nube_Rafa/Catalogos_Lightroom/Catalogo Rafa/Rafa-2 Previews.lrdata/0”) FINISHED WITH STATUS “RemoteHostClosedError Conexión cerrada” |
| [OCC::LsColXMLParser::parse | Invalid href “” expected starting with “/remote.php/dav/files/luismi/Nube_Rafa/Catalogos_Lightroom/Catalogo Rafa/Rafa-2 Previews.lrdata/0” |
| [OCC::DiscoverySingleDirectoryJob::lsJobFinishedWithErrorSlot | LSCOL job error “Conexión cerrada” 207 QNetworkReply::RemoteHostClosedError |
| [csync_ftw | opendir failed for Nube_Rafa/Catalogos_Lightroom/Catalogo Rafa/Rafa-2 Previews.lrdata/0 - errno 5 |
| [OCC::SyncEngine::handleSyncError | ERROR during csync_update : “Se produjo un error al abrir un directorio Conexión cerrada” |
| [OCC::ActivityWidget::addError | Item “Nextcloud” retrieved resulted in “Se produjo un error al abrir un directorio Conexión cerrada” |
| [OCC::ActivityListModel::addErrorToActivityList | Error successfully added to the notification list: “Se produjo un error al abrir un directorio Conexión cerrada” |
| [OCC::SyncJournalDb::close | Closing DB “/Users/luismi/Nextcloud/._sync_5695e7f17a0d.db” |
| [OCC::SyncEngine::finalize | CSync run took 365374 ms |
| [OCC::SocketListener::sendMessage | Sending SocketAPI message → “STATUS:OK:/Users/luismi/Nextcloud” to SocketApiSocket(0x600003437b60) |
| [OCC::Folder::slotSyncFinished | Client version 2.6.4stable (build 20200303) Qt 5.12.5 SSL OpenSSL 1.1.1d 10 Sep 2019 |
| [OCC::Folder::slotSyncFinished | SyncEngine finished with ERROR |
| [OCC::Folder::showSyncResultPopup | Folder sync result: 2 |
It also fails me with small files.
So it fails for all files?
Can you check the server log files?
What logs? I don’t know what logs I have to look at … Do you mean the Apache ones?
Nextcloud itself has a log file.
https://docs.nextcloud.com/server/18/admin_manual/configuration_server/logging_configuration.html
Your webserver as well.
Doctrine\DBAL\Exception\DeadlockException: An exception occurred while executing ‘UPDATE oc_file_locks SET lock = 1, ttl = ? WHERE key = ? AND lock = -1’ with params [1586963090, “files/ef8cc46b2bb5795be0ee3590b356ad46”]: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction
