Synchro via Davx5 is OK for contacts but KO for calendars
for several years I’ve been synchronizing my contacts and calendar from nextcloud, (nclood Zaclys), on one side with thunderbird and on the other on my mobile, an old Samsung Galaxy A3. For a few days, Davx5 had been indicating synchro problems with one of my calendars, but no problems with the other calendars. So I created a new calendar to get around the problem, but the synchro didn’t work any better with this new calendar. It was still good for the others.
I reinstalled Davx5. Synchronization is fine for contacts. The list of available calendars on nxtcloud appears fine. Davx5 doesn’t send any error message but I don’t have any data on my mobile.
I’ve installed ICSx5 and subscribed to one of the diaries and I’ve got the same thing: ICSx5 “says” the synchro is done but I’ve got no data on my mobile.
I’ve created an account on another Samsung mobile, a little more recent, and I’m having the same problem.
Thanks in advance for your help!
La réponse était simple (fournie par Davx5) : “Si vous utilisez l’application Google Calendar sur Android, vous devrez peut-être activer l’affichage des “calendriers non Google” dans les paramètres de l’application Google Calendar.
Ils n’affichent plus les calendriers synchronisés par défaut.”
I take it you run Android on your phone?
Google has been upsetting the Nextcloud app lately. It seems all recent version of the app exhibit some kinds of problems. Davx5 may well be impacted by this.
Which version of the Nextcloud app do you run, and from where is it installed? (The F-droid version has fewer problems than the Google version)
I’m not sure if this may help, but one of our users had issues yesterday, and while helping her, I noticed yesterday that she had 2 google-play automatic DAVx upgrades in a row: 4.4.5 → 4.4.4 and then 4.4.4 → 4.4.7.
At similar time, her appointments and DAVx nextcloud calendar account disappeared on her android phone (not just a disconnect, the account in accounts disappeared). She had to re-add it twice, change her password on nextcloud server, and as key wasn’t matching, she had also to revoke the DAVx5 keys in NexctCloud session. Then it worked.
Looking with her at her “Devices and sessions”, I noticed several sessions for DAVx, which were named by DAVx version:
DAVx5 - 4.4.7-gplay
DAVx5 - 4.4.4-gplay
DAVx5 - 4.4.5-gplay
Maybe that is the cause of this ?
It looks like a recurring issue, reported in many threads since quite some time. I didn’t have that issue with with the old good CalDAV app.
e.g. unsolved
Nextcloud Hub 9 (30.0.5)
PHP Version: 8.3.16
mysql Version: 8.0.41
Operating System: Linux 5.4.0-205-generic x86_64
Posting this here to help other users with this DAVx5 issues, and also, maybe to help NextCloud or DAVx5 devs fixing this issue. Thanks in advance for your look at these issues.
One more hint, in NextCloud logs, i had this error:
 InvalidTokenException Token does not exist: token does not exist
Renewing session token failed: Token does not exist: token does not exist
Hi beatb,
Welcome to the forums!
I’m sure it will help a fellow Nextcloud user, thanks for signing up to make people aware of this!
