Is it possible to sync notes between serveral different nextcloud servers?
Thanks
Thanks
What you could do (if the servers are federated) is:
Use the simple official notes app on one of the nextcloud instances.
This works because notes app uses the same folder name “notes” and the shared folder is also placed in the other users root folder.
Don’t know if this is officially supported but after performing a quick test it works for me.
It will probably lead to syncing problems due to versioning conflicts if the same note is edited in parallel.
This approach might as well work with other notes apps that save their data in a folder/file structure within the users file space.
Privacy note: Of course all notes both (or many) users create or edit with “notes” app will be visible/editable by the other user(s) (and accessible to system admins) on all participating nextcloud servers.
