example
longer
example
here
Nextcloud version (eg, 20.0.5): 28.0.1
Operating system and version (eg, Ubuntu 20.04): Alpine 3.18
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
I am using the Memories app and Recognize to detect faces in photos. I have tagged several faces with names. I have shared my photos folder with other users. Is it possible to share the names of the faces I’ve tagged with the other users I’ve shared my photos with?
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
