Sync Connection Timeout
I created a fresh NC 30 installation with existing files on the server. Synced those with “occ files:scan”. All works perfect on Android and via Web-Browser. On Windows I synced with Virtual File Support, also those synced and all my files are visible. I can double-click files and they download automatically and view them.
So far so fine. When I enable “Always keep on this device” on the root folder, it starts syncing but errors on various files - I force to resync all and it erros on other files.
Nextcloud Hub 9 (30.0.0)
Nextcloud desktop client 3.14.0
Thank you for your suggestions and support!
I have the same issue. I reverted to the older version of the desktop sync app. It does the job, but it gets updated automatically and the bug is back!
Thank god it’s not just me and that the thread is only a day old. I’m having the same problem.
