Sync client not in system tray
I’m on Linux Mint 22 (cinnamon desktop) and the desktop sync client (3.13.2) does not show up in the system tray. When I run the appimage it seems to already be running and my files are updated, but the window just disappears if I click outside of it.
Any help?
Seems to be a known problem:
Thank you for finding that info!
To be clear, though, that bug seems to be “systray icon […] show[s] only an alert icon”, but I don’t have any sync client-icon at all in the systray… Also, the suggested fix seems to be to use the appimage instead of the flatpak version, and I already use the appimage.
