Suddenly "Error - IP" on both Port 80 and 443 checks in lxc container and no connection to nextcloud
Not sure how this has happened but suddenly i cannot ping from inside my lxc container to anything outside.
i.e.
lxc ncp ping 192.168.1.1 (my router)
gets you
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
^C
— 192.168.1.1 ping statistics —
3 packets transmitted, 0 received, 100% packet loss, time 2051ms
I tired setting up a new bridge with
lxc network create
lxc network attach … alternative eth1
restarted but same behavior…
My lxc knowledge is limited i must say…
inside the container there are these processes running
USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root           1  0.1  0.1 100084 10216 ?        Ss   10:32   0:00 /sbin/init
root          67  0.0  0.2  40212 18200 ?        Ss   10:32   0:00 /lib/systemd/systemd-journald
root          75  0.0  0.0  20640  4888 ?        Ss   10:32   0:00 /lib/systemd/systemd-udevd
systemd+      78  0.0  0.0  16076  6140 ?        Ss   10:32   0:00 /lib/systemd/systemd-networkd
systemd+      85  0.0  0.1  24196 12408 ?        Ss   10:32   0:00 /lib/systemd/systemd-resolved
avahi         87  0.0  0.0   7412  3672 ?        Ss   10:32   0:00 avahi-daemon: running [ncp.local]
root          88  0.0  0.0   6768  2816 ?        Ss   10:32   0:00 /usr/sbin/cron -f
message+      89  0.0  0.0   8264  4164 ?        Ss   10:32   0:00 /usr/bin/dbus-daemon --system --address=systemd: --no
root          92  0.0  0.0  13564  5796 ?        Ss   10:32   0:00 /lib/systemd/systemd-logind
avahi         94  0.0  0.0   7148   340 ?        S    10:32   0:00 avahi-daemon: chroot helper
root         111  0.0  0.4 253052 35644 ?        Ss   10:32   0:00 php-fpm: master process (/etc/php/8.1/fpm/php-fpm.con
root         114  0.1  0.2  29632 18428 ?        Ss   10:32   0:00 /usr/bin/python3 /usr/share/unattended-upgrades/unatt
root         121  0.0  0.0   5476  2164 pts/0    Ss+  10:32   0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud consol
www-data     139  1.2  0.7 330504 55640 ?        S    10:32   0:02 php-fpm: pool www
www-data     140  0.5  0.6 328196 51484 ?        S    10:32   0:00 php-fpm: pool www
www-data     141  0.2  0.7 331308 55488 ?        S    10:32   0:00 php-fpm: pool www
www-data     142  0.3  0.7 335240 58468 ?        S    10:32   0:00 php-fpm: pool www
www-data     146  0.6  0.7 331156 56700 ?        S    10:32   0:01 php-fpm: pool www
www-data     147  0.8  0.6 332456 53668 ?        S    10:32   0:01 php-fpm: pool www
root         149  0.0  0.1  12540  8496 ?        Ss   10:32   0:00 /usr/sbin/apache2 -k start
www-data     152  0.0  0.1 1423404 9064 ?        Sl   10:32   0:00 /usr/sbin/apache2 -k start
www-data     153  0.0  0.1 1423708 9344 ?        Sl   10:32   0:00 /usr/sbin/apache2 -k start
mysql        346  1.1  5.2 3472004 404264 ?      Ssl  10:32   0:02 /usr/sbin/mariadbd
root         402  0.0  0.2  68340 16360 ?        Ss   10:32   0:00 /usr/sbin/nmbd --foreground --no-process-group
root        1265  0.0  0.0  40048  5004 ?        Ss   10:32   0:00 /usr/lib/postfix/sbin/master -w
postfix     1266  0.0  0.0  40304  6880 ?        S    10:32   0:00 pickup -l -t unix -u -c
postfix     1267  0.0  0.0  40352  6756 ?        S    10:32   0:00 qmgr -l -t unix -u
redis       1380  1.1  0.1  76940 14116 ?        Ssl  10:33   0:02 /usr/bin/redis-server 127.0.0.1:0
root        1577  0.2  0.0  10592  5536 pts/1    Ss   10:35   0:00 bash
root        1648  0.0  0.0  10204  3868 ?        S    10:40   0:00 /usr/sbin/CRON -f
root        1650  0.0  0.0   2480   576 ?        Ss   10:40   0:00 /bin/sh -c /usr/local/bin/ncp-notify-update && /usr/l
root        1651  0.0  0.0   7212  3848 ?        S    10:40   0:00 /bin/bash /usr/local/bin/ncp-notify-update
root        1664  0.0  0.0   7212  3624 ?        S    10:40   0:00 /bin/bash /usr/local/bin/ncp-check-nc-version
root        1680  0.0  0.0   7212  2132 ?        S    10:40   0:00 /bin/bash /usr/local/bin/ncp-check-nc-version
root        1681  0.0  0.1  16428  8972 ?        S    10:40   0:00 wget -qO- https://raw.githubusercontent.com/nextcloud
root        1682  0.0  0.0   5244  3080 ?        S    10:40   0:00 jq -r .nextcloud_version
root        1709  0.0  0.0  11812  3672 pts/1    R+   10:42   0:00 ps -aux
and the output of ncp-report is like this:
NextCloudPi diagnostics
NextCloudPi version  v1.50.5
NextCloudPi image    NextCloudPi_LXD_01-08-23.img
OS                   Debian GNU/Linux 11. 5.15.0-72-generic (x86_64)
automount            yes
USB devices          sdb sdc
datadir              /media/1c2e55ef-caf9-4713-a9f0-9082082ed80c/ncdata
data in SD           yes
data filesystem      btrfs
data disk usage      1.4T/3.7T
rootfs usage         6.4G/21G
swapfile             none
dbdir                /var/lib/mysql
Nextcloud check      ok
Nextcloud version    24.0.8.2
HTTPD service        up
PHP service          up
MariaDB service      up
Redis service        up
HPB service          down
Postfix service      up
Internet check       no
public IP            ***REMOVED SENSITIVE VALUE***
Port check 80        Error - IP                                          ***REMOVED SENSITIVE VALUE***
Port check 443       Error - IP                                          ***REMOVED SENSITIVE VALUE***
gateway              ***REMOVED SENSITIVE VALUE***
Interface            eth0
certificates         ***REMOVED SENSITIVE VALUE***
NAT loopback         no
Uptime               11min
Nextcloud configuration
        "trusted_domains": {
            "0": "localhost",
            "11": "xxx",
            "1": "xxx",
            "5": "nextcloudpi.local",
            "7": "nextcloudpi",
            "8": "nextcloudpi.lan",
            "2": "xxx",
            "3": "ncp",
            "14": "ncp",
            "15": "xxx,
            "16": "192.168.1.98"
        "dbtype": "mysql",
        "version": "24.0.8.2",
        "overwrite.cli.url": "https:\/\/ncp\/",
        "dbport": "",
        "mysql.utf8mb4": true,
        "cache_path": "\/media\/1c2e55ef-caf9-4713-a9f0-9082082ed80c\/nccache\/",
        "redis": {
            "port": 0,
            "timeout": 0,
        "tempdirectory": "\/media\/1c2e55ef-caf9-4713-a9f0-9082082ed80c\/ncdata\/tmp",
        "mail_smtpmode": "sendmail",
        "mail_smtpauthtype": "LOGIN",
        "preview_max_x": "2048",
        "preview_max_y": "2048",
        "jpeg_quality": "60",
        "overwriteprotocol": "https",
        "data-fingerprint": "398bc94ae7e1eb7ae56dbf1d7872b007",
        "theme": "",
        "logfile": "\/media\/1c2e55ef-caf9-4713-a9f0-9082082ed80c\/ncdata\/nextcloud.log",
        "loglevel": 2,
        "log_type": "file",
        "app_install_overwrite": [
            "gallery"
        "mail_sendmailmode": "smtp",
        "trusted_proxies": "***REMOVED SENSITIVE VALUE***"
HTTPd logs
[Fri May 19 10:20:30.557907 2023] [mpm_event:notice] [pid 150:tid 140553790790976] AH00492: caught SIGWINCH, shutting down gracefully
[Fri May 19 10:21:33.933972 2023] [ssl:warn] [pid 128:tid 140714564074816] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri May 19 10:21:34.028362 2023] [ssl:warn] [pid 137:tid 140714564074816] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri May 19 10:21:34.076671 2023] [mpm_event:notice] [pid 137:tid 140714564074816] AH00489: Apache/2.4.56 (Debian) OpenSSL/1.1.1n configured -- resuming normal operations
[Fri May 19 10:21:34.076728 2023] [core:notice] [pid 137:tid 140714564074816] AH00094: Command line: '/usr/sbin/apache2'
[Fri May 19 10:22:59.393152 2023] [mpm_event:notice] [pid 137:tid 140714564074816] AH00492: caught SIGWINCH, shutting down gracefully
[Fri May 19 10:24:00.499108 2023] [ssl:warn] [pid 132:tid 140325788876096] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri May 19 10:24:00.562308 2023] [ssl:warn] [pid 143:tid 140325788876096] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri May 19 10:24:00.564749 2023] [mpm_event:notice] [pid 143:tid 140325788876096] AH00489: Apache/2.4.56 (Debian) OpenSSL/1.1.1n configured -- resuming normal operations
[Fri May 19 10:24:00.564790 2023] [core:notice] [pid 143:tid 140325788876096] AH00094: Command line: '/usr/sbin/apache2'
[Fri May 19 10:25:58.153937 2023] [mpm_event:notice] [pid 143:tid 140325788876096] AH00492: caught SIGWINCH, shutting down gracefully
[Fri May 19 10:27:30.070759 2023] [ssl:warn] [pid 153:tid 140094337703232] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri May 19 10:27:30.127794 2023] [ssl:warn] [pid 259:tid 140094337703232] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri May 19 10:27:30.146096 2023] [mpm_event:notice] [pid 259:tid 140094337703232] AH00489: Apache/2.4.56 (Debian) OpenSSL/1.1.1n configured -- resuming normal operations
[Fri May 19 10:27:30.146146 2023] [core:notice] [pid 259:tid 140094337703232] AH00094: Command line: '/usr/sbin/apache2'
[Fri May 19 10:32:46.183005 2023] [mpm_event:notice] [pid 259:tid 140094337703232] AH00492: caught SIGWINCH, shutting down gracefully
[Fri May 19 10:32:53.448591 2023] [ssl:warn] [pid 128:tid 140592942730560] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri May 19 10:32:53.488514 2023] [ssl:warn] [pid 149:tid 140592942730560] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri May 19 10:32:53.490926 2023] [mpm_event:notice] [pid 149:tid 140592942730560] AH00489: Apache/2.4.56 (Debian) OpenSSL/1.1.1n configured -- resuming normal operations
[Fri May 19 10:32:53.490971 2023] [core:notice] [pid 149:tid 140592942730560] AH00094: Command line: '/usr/sbin/apache2'
Database logs
tail: cannot open '/var/log/mysql/*.log' for reading: No such file or directory
Nextcloud logs
{"reqId":"ZFFW0ath58Kjg_Q0ybDpXgAADhQ","level":3,"time":"2023-05-02T18:30:49+00:00","remoteAddr":"127.0.0.1","user":"--","app":"no app in context","method":"PUT","url":"/public.php/webdav/P1002529.JPG","message":"Erwartete Dateigr\u00f6\u00dfe von 10563072 bytes, aber 2678784 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"24.0.8.2","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Erwartete Dateigr\u00f6\u00dfe von 10563072 bytes, aber 2678784 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":164,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/publicwebdav.php","line":117,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/public.php","line":80,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/publicwebdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":297,"CustomMessage":"--"}}
{"reqId":"ZFFaWKth58Kjg_Q0ybDq7gAAFBQ","level":3,"time":"2023-05-02T18:51:12+00:00","remoteAddr":"127.0.0.1","user":"--","app":"no app in context","method":"PUT","url":"/public.php/webdav/P1002630.JPG","message":"Erwartete Dateigr\u00f6\u00dfe von 10125312 bytes, aber 10117120 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"24.0.8.2","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Erwartete Dateigr\u00f6\u00dfe von 10125312 bytes, aber 10117120 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":164,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/publicwebdav.php","line":117,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/public.php","line":80,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/publicwebdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":297,"CustomMessage":"--"}}
{"reqId":"ZFFcYqth58Kjg_Q0ybDrnwAACAo","level":3,"time":"2023-05-02T18:59:52+00:00","remoteAddr":"127.0.0.1","user":"--","app":"no app in context","method":"PUT","url":"/public.php/webdav/P1002668.JPG","message":"Erwartete Dateigr\u00f6\u00dfe von 9615360 bytes, aber 9609216 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"24.0.8.2","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Erwartete Dateigr\u00f6\u00dfe von 9615360 bytes, aber 9609216 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":164,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/publicwebdav.php","line":117,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/public.php","line":80,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/publicwebdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":297,"CustomMessage":"--"}}
{"reqId":"ZFFyHath58Kjg_Q0ybDwdAAAAA8","level":3,"time":"2023-05-02T20:29:40+00:00","remoteAddr":"127.0.0.1","user":"tatjana","app":"no app in context","method":"PUT","url":"/remote.php/dav/uploads/tatjana/05fe9972e4ff12f3f1635b3eaf64c6bb/0000000000000000-0000000002805547","message":"Expected filesize of 2805547 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 1810432 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.24.1","version":"24.0.8.2","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 2805547 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 1810432 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":164,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Upload/UploadFolder.php","line":45,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":358,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":170,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":297,"CustomMessage":"--"}}
{"reqId":"Cnc00AUEfQzrbO05MtMK","level":4,"time":"2023-05-15T16:56:08+00:00","remoteAddr":"","user":"--","app":"nextcloudpi","method":"","url":"--","message":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"read error on connection to /var/run/redis/redis.sock:0","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0","exception":{},"CustomMessage":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0"}}
{"reqId":"Cnc00AUEfQzrbO05MtMK","level":4,"time":"2023-05-15T16:56:08+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Could not boot notify_push: No such file or directory","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"No such file or directory","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/RedisFactory.php","line":137,"function":"pconnect","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/private/RedisFactory.php","line":178,"function":"create","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/nextcloud/apps/notify_push/lib/AppInfo/Application.php","line":62,"function":"getInstance","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":162,"function":"OCA\\NotifyPush\\AppInfo\\{closure}","class":"OCA\\NotifyPush\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":122,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":129,"function":"offsetGet","class":"Pimple\\Container","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":459,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":437,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":89,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":437,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":57,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":50,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"function":"OC\\AppFramework\\Bootstrap\\{closure}","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/nextcloud/apps/notify_push/lib/AppInfo/Application.php","line":70,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":190,"function":"boot","class":"OCA\\NotifyPush\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":207,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/RedisFactory.php","Line":137,"message":"Could not boot notify_push: No such file or directory","exception":{},"CustomMessage":"Could not boot notify_push: No such file or directory"}}
{"reqId":"Cnc00AUEfQzrbO05MtMK","level":4,"time":"2023-05-15T16:56:08+00:00","remoteAddr":"","user":"--","app":"oauth2","method":"","url":"--","message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"Redis server /var/run/redis/redis.sock:0 went away","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","exception":{},"CustomMessage":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away"}}
{"reqId":"Cnc00AUEfQzrbO05MtMK","level":4,"time":"2023-05-15T16:56:08+00:00","remoteAddr":"","user":"--","app":"privacy","method":"","url":"--","message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"Redis server /var/run/redis/redis.sock:0 went away","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","exception":{},"CustomMessage":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away"}}
{"reqId":"Cnc00AUEfQzrbO05MtMK","level":4,"time":"2023-05-15T16:56:08+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Could not boot richdocuments: Redis server /var/run/redis/redis.sock:0 went away","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"Redis server /var/run/redis/redis.sock:0 went away","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":69,"function":"del","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/apps/richdocuments/lib/WOPI/DiscoveryManager.php","line":101,"function":"remove","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/nextcloud/apps/richdocuments/lib/AppInfo/Application.php","line":217,"function":"refetch","class":"OCA\\Richdocuments\\WOPI\\DiscoveryManager","type":"->"},{"file":"/var/www/nextcloud/apps/richdocuments/lib/AppInfo/Application.php","line":152,"function":"checkAndEnableCODEServer","class":"OCA\\Richdocuments\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":190,"function":"boot","class":"OCA\\Richdocuments\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":207,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":69,"message":"Could not boot richdocuments: Redis server /var/run/redis/redis.sock:0 went away","exception":{},"CustomMessage":"Could not boot richdocuments: Redis server /var/run/redis/redis.sock:0 went away"}}
{"reqId":"Cnc00AUEfQzrbO05MtMK","level":4,"time":"2023-05-15T16:56:08+00:00","remoteAddr":"","user":"--","app":"richdocumentscode","method":"","url":"--","message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"Redis server /var/run/redis/redis.sock:0 went away","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","exception":{},"CustomMessage":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away"}}
{"reqId":"8YR6hPtOyVIeR5t78d8o","level":3,"time":"2023-05-15T18:05:32+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"An exception occurred while executing a query: SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing a query: SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","Code":1927,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1780,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1719,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1067,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":227,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":145,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":114,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","Code":1927,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":94,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1057,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":227,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":145,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":26,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","Code":"70100","Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":92,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1057,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":227,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":145,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":92}},"CustomMessage":"--"}}
{"reqId":"dvnkNdiVhTDmtEJ3s1IN","level":2,"time":"2023-05-16T06:25:32+00:00","remoteAddr":"","user":"--","app":"appstoreFetcher","method":"","url":"--","message":"Could not connect to appstore: cURL error 28: Failed to connect to apps.nextcloud.com port 443: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","userAgent":"--","version":"24.0.8.2","data":{"app":"appstoreFetcher"}}
{"reqId":"FufamtSaDOFaJL35Fb27","level":4,"time":"2023-05-17T06:29:28+00:00","remoteAddr":"","user":"--","app":"nextcloudpi","method":"","url":"--","message":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"read error on connection to /var/run/redis/redis.sock:0","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0","exception":{},"CustomMessage":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0"}}
{"reqId":"FufamtSaDOFaJL35Fb27","level":4,"time":"2023-05-17T06:29:28+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Could not boot notify_push: No such file or directory","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"No such file or directory","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/RedisFactory.php","line":137,"function":"pconnect","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/private/RedisFactory.php","line":178,"function":"create","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/nextcloud/apps/notify_push/lib/AppInfo/Application.php","line":62,"function":"getInstance","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":162,"function":"OCA\\NotifyPush\\AppInfo\\{closure}","class":"OCA\\NotifyPush\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php","line":122,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":129,"function":"offsetGet","class":"Pimple\\Container","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":459,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":437,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":89,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":437,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":57,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":50,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"function":"OC\\AppFramework\\Bootstrap\\{closure}","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/nextcloud/apps/notify_push/lib/AppInfo/Application.php","line":70,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":190,"function":"boot","class":"OCA\\NotifyPush\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":207,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/RedisFactory.php","Line":137,"message":"Could not boot notify_push: No such file or directory","exception":{},"CustomMessage":"Could not boot notify_push: No such file or directory"}}
{"reqId":"FufamtSaDOFaJL35Fb27","level":4,"time":"2023-05-17T06:29:28+00:00","remoteAddr":"","user":"--","app":"oauth2","method":"","url":"--","message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"Redis server /var/run/redis/redis.sock:0 went away","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","exception":{},"CustomMessage":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away"}}
{"reqId":"FufamtSaDOFaJL35Fb27","level":4,"time":"2023-05-17T06:29:28+00:00","remoteAddr":"","user":"--","app":"privacy","method":"","url":"--","message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"Redis server /var/run/redis/redis.sock:0 went away","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","exception":{},"CustomMessage":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away"}}
{"reqId":"FufamtSaDOFaJL35Fb27","level":4,"time":"2023-05-17T06:29:28+00:00","remoteAddr":"","user":"--","app":"richdocumentscode","method":"","url":"--","message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"Redis server /var/run/redis/redis.sock:0 went away","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away","exception":{},"CustomMessage":"Error during app loading: Redis server /var/run/redis/redis.sock:0 went away"}}
{"reqId":"CShRdNmEuZBw0UrUq1yv","level":2,"time":"2023-05-18T06:25:36+00:00","remoteAddr":"","user":"--","app":"appstoreFetcher","method":"","url":"--","message":"Could not connect to appstore: cURL error 28: Failed to connect to apps.nextcloud.com port 443: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","userAgent":"--","version":"24.0.8.2","data":{"app":"appstoreFetcher"}}
{"reqId":"HpncAlnbjgOpp6BlIJDy","level":2,"time":"2023-05-19T06:25:32+00:00","remoteAddr":"","user":"--","app":"appstoreFetcher","method":"","url":"--","message":"Could not connect to appstore: cURL error 28: Failed to connect to apps.nextcloud.com port 443: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","userAgent":"--","version":"24.0.8.2","data":{"app":"appstoreFetcher"}}
{"reqId":"ghHeceKbxQpJBW3sRWH3","level":4,"time":"2023-05-19T10:33:01+00:00","remoteAddr":"","user":"--","app":"dashboard","method":"","url":"--","message":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0","userAgent":"--","version":"24.0.8.2","exception":{"Exception":"RedisException","Message":"read error on connection to /var/run/redis/redis.sock:0","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Memcache/Redis.php","line":48,"function":"get","class":"Redis","type":"->"},{"file":"/var/www/nextcloud/lib/autoloader.php","line":154,"function":"get","class":"OC\\Memcache\\Redis","type":"->"},{"function":"load","class":"OC\\Autoloader","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":207,"function":"class_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":172,"function":"isBootable","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":140,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":119,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Memcache/Redis.php","Line":48,"message":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0","exception":{},"CustomMessage":"Error during app loading: read error on connection to /var/run/redis/redis.sock:0"}}
Funney.
I went and connected via my local net to https://192… type ip.
of course there is a warning about the cert being for a different domain but i am able to connect to nextcloud without any problem.
Now my router is definitively set up to forward 80 and 443 to my nextcloud device. the ip is correct and there was no changes to the router config.
I tried setting my ncp host into a demilitarized zone (Which as asus describes opens all ports towards that IP) and tried again to no avail.
The IP that i get shown as my public IP is exactly that which the WAN ethernet port has (i sshd into the router to readout ifconfig | grep addr of that beast).
What else happened in the meantime:
I resetup the 80 and 443 lxc forwards.
i made a new instance of a LXC ncp image but then weird things started happening as obviously all my syncs saw an unsigned cert and started complaining.
is this somehow hinting at something?
Im running out of ideas.
new day new tests.
I followed the guide to setup a new lxc container based on this
ofc i ran the wizard and activated the new instance. Here i deffered from the guide and used the public ip of the host and not the container, but the activation dialogue opened nevertheless.
also available from “outside”
turns out i can acces the nc instance now from inside and outside of my network (still getting complaints about wrong certificates but yeah..) also after activation
however getting letsencrypt to go fails. also still not able to ping the outside world from inside the host, and also the same behavior in ncp-config (waiting for new version answer from the big big internet and noone answers…)
So… what could be the reason?
I investigated further and setup a new bridge network and relaunched the container. That yielded precisely the same results.
New ideas?
