Nextcloud version (eg, 20.0.5): linuxserver:latest
Operating system and version (eg, Ubuntu 20.04): Raspbery Pi OS “Bookworm”
Apache or nginx version (eg, Apache 2.4.25): Nignx
PHP version (eg, 7.4): replace me
I have been using this on a raspberry pi for several weeks without issue, today i have gone to log into the dashbaord and its asking me to create an admin account, which I have already done when i first installed. The users folder seems to have just vanished, luckily no data has been lost!
can somebody point towards what has happened here. I have asked in linuxserver and they pointed me here, both my /config and/data were pointing to my external storage. I really do not know what has happned here
There no longer is any config.php when i run (in the /nextcloud folder
find ./*config*
I get no such file or directory
I am using external storage for the nextcloud instane
N/A
(make sure you remove any identifiable information!): There is nothing there but i did find this under /nextcloud/log/php
[25-Jan-2024 18:44:20] NOTICE: Terminating ...
[25-Jan-2024 18:44:20] NOTICE: exiting, bye-bye!
[25-Jan-2024 18:45:11] NOTICE: fpm is running, pid 335
[25-Jan-2024 18:45:11] NOTICE: ready to handle connections
[25-Jan-2024 19:04:41] NOTICE: Terminating ...
[25-Jan-2024 19:04:41] NOTICE: exiting, bye-bye!
[25-Jan-2024 19:07:36] NOTICE: fpm is running, pid 312
[25-Jan-2024 19:07:36] NOTICE: ready to handle connections
[25-Jan-2024 19:46:07] NOTICE: Terminating ...
[25-Jan-2024 19:46:07] NOTICE: exiting, bye-bye!
2024/01/25 12:38:13 [error] 344#344: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.2.106, server: _, request: "GET /index.php/204 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "redacted.redacted:portnumber"
