Nextcloud version 15.0.14:
Operating system and version Ubuntu 16.04.7 LTS:
Apache or nginx version Apache/2.4.18 (Ubuntu):
PHP version 7.2:
I used the Updater to upgrade to 15.0.14 from whatever I was on before. Then updater told me “The updater is disabled for this update - please update manually.”
I get stuck when I try to upgrade with $ sudo -u www-data php occ upgrade
. I get the following error:
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: could not find driver in /var/www/nextcloud/lib/private/DB/Connection.php:64
Stack Trace:
Is this the first time you’ve seen this error? Y though I’ve restored the server from a snapshot and repeated with the same results.
- Follow this documentation with the exception of backup. I made a snapshot of the server instead. Upgrade manually — Nextcloud latest Administration Manual latest documentation
- When I reach
I get: This version of Nextcloud requires at least PHP 7.1
You are currently running 7.0.33-0ubuntu0.16.04.16. Please update your PHP version. I update to 7.2 following this answer on ask ubuntu: https://askubuntu.com/a/1111949 - I then try
again and get the above error. - php -m does not list pdo_mysql. I tried uncommenting
extension=pdo_mysql.so
in/etc/php/7.2/apache2/php.ini
but that did not help.
I can't get that from the webclient as it is not operational at the moment
root@LAMP-NC:/var/www/nextcloud# cat config/config.php
'instanceid' => '***********',
'passwordsalt' => '****************',
'secret' => '********************************',
0 => 'mync.com',
'overwrite.cli.url' => 'http://mync.com',
'version' => '15.0.14.1',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud_user',
'dbpassword' => '********',
'theme' => '',
'loglevel' => 2,
'updater.secret' => '******************,
'updater.release.channel' => 'production',
release channel was on stable, I changed it to try and get the updater to work
https://pastebin.com/cBDA8bWF
syslog appears to contain firewall activity for the most part
