Nextcloud version: 22.1.1
Operating system and version: Ubuntu 16.04
Apache version: Apache2
PHP version: 7.3
When I install Nextcloud, everything seems to go fine until it begins the installation. Then, it tries to redirect me to this url:
https://index.php/core/apps/recommended
Which is obviously wrong and goes nowhere. When I try to just go to the Nextcloud location, I get a branded, Nextcloud internal service error.
In the logs, it says proxy_fcgi:error AH01071 ‘primary script unknown’.
Is this the first time you’ve seen this error? Yes.
I can't seem to get the log to populate again right now, I don't know why. But I posted the relevant error
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'i.website.org',
'version' => '22.1.1.2',
'overwrite.cli.url' => 'https://i.website.org',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'xxx',
[Sat Sep 04 20:45:05.457915 2021] [:notice] [pid 4242] FastCGI: process manager initialized (pid 4242)
[Sat Sep 04 20:45:05.483937 2021] [mpm_prefork:notice] [pid 4241] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 20:45:05.483987 2021] [core:notice] [pid 4241] AH00094: Command line: '/usr/sbin/apache2'
[Sat Sep 04 20:45:21.503981 2021] [mpm_prefork:notice] [pid 4241] AH00169: caught SIGTERM, shutting down
[Sat Sep 04 20:45:21.573485 2021] [:notice] [pid 4304] FastCGI: process manager initialized (pid 4304)
[Sat Sep 04 20:45:21.601508 2021] [mpm_prefork:notice] [pid 4303] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 20:45:21.601555 2021] [core:notice] [pid 4303] AH00094: Command line: '/usr/sbin/apache2'
[Sat Sep 04 20:49:16.064615 2021] [mpm_prefork:notice] [pid 4303] AH00169: caught SIGTERM, shutting down
[Sat Sep 04 20:49:16.143467 2021] [:notice] [pid 5244] FastCGI: process manager initialized (pid 5244)
[Sat Sep 04 20:49:16.207725 2021] [mpm_prefork:notice] [pid 5243] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 20:49:16.207792 2021] [core:notice] [pid 5243] AH00094: Command line: '/usr/sbin/apache2'
[Sat Sep 04 20:51:28.157220 2021] [mpm_prefork:notice] [pid 5243] AH00169: caught SIGTERM, shutting down
[Sat Sep 04 20:51:28.224350 2021] [:notice] [pid 5680] FastCGI: process manager initialized (pid 5680)
[Sat Sep 04 20:51:28.259792 2021] [mpm_prefork:notice] [pid 5679] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 20:51:28.259844 2021] [core:notice] [pid 5679] AH00094: Command line: '/usr/sbin/apache2'
[Sat Sep 04 20:52:53.054662 2021] [mpm_prefork:notice] [pid 5679] AH00169: caught SIGTERM, shutting down
[Sat Sep 04 20:52:53.151404 2021] [:notice] [pid 5923] FastCGI: process manager initialized (pid 5923)
[Sat Sep 04 20:52:53.167698 2021] [mpm_prefork:notice] [pid 5922] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 20:52:53.167781 2021] [core:notice] [pid 5922] AH00094: Command line: '/usr/sbin/apache2'
[Sat Sep 04 21:11:30.326888 2021] [mpm_prefork:notice] [pid 5922] AH00169: caught SIGTERM, shutting down
[Sat Sep 04 21:11:30.405856 2021] [:notice] [pid 7847] FastCGI: process manager initialized (pid 7847)
[Sat Sep 04 21:11:30.433916 2021] [mpm_prefork:notice] [pid 7846] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 21:11:30.433958 2021] [core:notice] [pid 7846] AH00094: Command line: '/usr/sbin/apache2'
[Sat Sep 04 21:24:16.870391 2021] [mpm_prefork:notice] [pid 7846] AH00169: caught SIGTERM, shutting down
[Sat Sep 04 21:24:16.941012 2021] [:notice] [pid 9047] FastCGI: process manager initialized (pid 9047)
[Sat Sep 04 21:24:17.114361 2021] [mpm_prefork:notice] [pid 9046] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 21:24:17.114421 2021] [core:notice] [pid 9046] AH00094: Command line: '/usr/sbin/apache2'
[Sat Sep 04 21:25:59.643603 2021] [mpm_prefork:notice] [pid 9046] AH00169: caught SIGTERM, shutting down
[Sat Sep 04 21:25:59.709988 2021] [:notice] [pid 9245] FastCGI: process manager initialized (pid 9245)
[Sat Sep 04 21:25:59.736998 2021] [mpm_prefork:notice] [pid 9244] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 21:25:59.737047 2021] [core:notice] [pid 9244] AH00094: Command line: '/usr/sbin/apache2'
[Sat Sep 04 21:39:40.636917 2021] [mpm_prefork:notice] [pid 9244] AH00169: caught SIGTERM, shutting down
[Sat Sep 04 21:41:22.731632 2021] [:notice] [pid 10906] FastCGI: process manager initialized (pid 10906)
[Sat Sep 04 21:41:22.758670 2021] [mpm_prefork:notice] [pid 10905] AH00163: Apache/2.4.46 (Ubuntu) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.1.1g configured -- resuming normal operations
[Sat Sep 04 21:41:22.758710 2021] [core:notice] [pid 10905] AH00094: Command line: '/usr/sbin/apache2'
